Cattman Coilovers Arrived...56k will be slow....
Old Feb 13, 2007 | 12:46 AM
NISMOPower's Avatar
Cattman Coilovers Arrived...56k will be slow....Updated Photos 2.13.07
Just wanted to post some photos of the unpacking of the coilovers plus some bushings....
NISMOPower's Avatar
Old Feb 13, 2007 | 12:47 AM
NISMOPower's Avatar
NISMOPower's Avatar
Old Feb 13, 2007 | 12:51 AM
glenmoormax's Avatar
10 psi
those are looking nice... post updates...!
Old Feb 13, 2007 | 12:56 AM
meccanoble's Avatar
Sports Button FTW
thats whats up, dam and u got nice weather over there in the west, so jealous. The saga continues lol
Old Feb 13, 2007 | 07:27 AM
Phaedrus220's Avatar
100 posts/7 years - woot!
I recently got the same kit from Cattman, had them installed at Maximum Tuning. At the same time, w/145k on the original suspension, replaced as much rubber as possible w/ES bushings, plus new tie rod ends (inner and outer) and LCAs.
I ended up raising the coilovers a 1/2 inch (8 turns) from what Cattman recommends, because the drop was too low. As is now, the height is good, with alot of the wheel well gap closed up.
Pros: At this point, I can dive into any off ramp as fast as I want, an incredible difference from the stock handling. With the rsb and fstb, it's amazing how level the car remains no matter what I do. I drove my chick's Altima recently just to remind myself of what the stock handling was like.
Cons: I'm experiencing squeaks that are annoying, particularly from the rear...if they continue, I'll want someone w/more knowledge to tell me what's going on. I know coilovers are prone to this, but I had hoped that since the kit was designed for Maximas that it wouldn't be the case.
Old Feb 13, 2007 | 07:38 AM
DCP's Avatar
DCP
Poly Bushings are known to make more noise than the stock rubber bushings, since they are more rigid and dont give as much.
Old Feb 13, 2007 | 07:55 AM
ray_289's Avatar
How much does this kit go for?
Old Feb 13, 2007 | 08:05 AM
OOmaxSE's Avatar
If bushings are the case, I would HEAVILY grease it up with some "white lithium." This will at least temperarily cure it and you will now know where to pinpoint the squeaks.
Are these the coilovers that are "conditioned" for the maxima?? Meaning no dampening adjustments?
Old Feb 13, 2007 | 08:18 AM
Cdg2125's Avatar
Those things are very nice. How much do they run for now?
Old Feb 13, 2007 | 08:26 AM
Good advice OOmaxSE, thanks....I'll try that if the weather gets over 30 degrees this weekend!
btw, Cattman has the kit on his weekly sale post. And yes, dampening is not adjustable, only ride height, as these are designed for the max.
Old Feb 13, 2007 | 08:34 AM
Cdg2125's Avatar
So dampering is already set, so no bottom outs?
Old Feb 13, 2007 | 09:00 AM
Iron Scimitar's Avatar
Tha Snatcher
I've never seen coilovers that you have to assemble yourself
Old Feb 13, 2007 | 09:13 AM
maximaA33ny's Avatar
Yes,some coilovers you have to assemble yourself. Never seen one for a maxima where you have to assemble yourself, guess this is a first. Post pics when you assemble them NISMOpower
Old Feb 13, 2007 | 09:32 AM
MDeezy's Avatar
I was shocked cause I didnt know cattman offered Coilovers for us, and man would have been nice to get them pre-assembled.
looks like you should have a smoother ride (pending on dapening,pre-load settigns).
Old Feb 13, 2007 | 09:41 AM
ewuzh's Avatar
They partnered with Progress Suspension to develop them. I thought about them, but despite the arguments against it, I still wanted something with adjustable dampening.
Old Feb 13, 2007 | 11:03 AM
NISMOPower's Avatar
I've already taken some photos of the assembly with the rears so far, I will be doing the fronts today. Unfortunately I didn't have the tools in my bedroom since all my tools are at a friends house.
I'll probably have them on tonight....
Here is a roundup for what I purchased everything for, also posted in group deal forum from Cattman (Pleasure to work with Brian):
Coilovers: 1100
ES Bushings: 71
Camber Bolts: 45
2 Upper strut Mounts:82
Old Feb 13, 2007 | 12:21 PM
Toolatecrew's Avatar
That's a big frekn box.
How low is the drop you anticipate from this kit?
Old Feb 13, 2007 | 12:58 PM
MDeezy's Avatar
they are coil overs so he adjust the height. unless you meant to ask how long he anticipates on going....
Old Feb 13, 2007 | 01:29 PM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
Damn Chris, that's alot of mods. You have to let me know how u like everything when u get it installed, I need to install my ES bushings still.
Old Feb 13, 2007 | 01:38 PM
Jupak's Avatar
sweet, but thats pretty expensive
Old Feb 13, 2007 | 04:08 PM
Bonka's Avatar
Schnell kaputt
Surprised at how many members here have Progress coilovers. I'm waiting to have mine installed. It was either between these or the Teins I figured I'd give these a shot. Haven't heard much about the brand myself.
Old Feb 13, 2007 | 04:18 PM
Fr33way™'s Avatar
Wild for Width
I think the great thing is having a guy like Cattman behind them. I'm sure it's the exact opposite of dealing with D2 Racing Sport.
Old Feb 13, 2007 | 07:52 PM
NISMOPower's Avatar
Updated Photos
Some shots for those who want to see... Decided to wait for the ES Suspension to be done on another day. I was using another Org Members garage while he was at work...All my tools are there...Thanks Grant (Sig=MaxBoost something).
I basically came off of AGX/Sprints (Rear 1coil Cut, Which is also for sale now). Just on the ride home, the suspension feels more direct like I know what is going on. Need to get an alignment done, once i'm able to really see what the big deal coilovers are i'll let you guys know. And don't worry I will fully test these out.....
Picture of wheel gap is the fronts...
NISMOPower's Avatar
Old Feb 13, 2007 | 07:53 PM
NISMOPower's Avatar
NISMOPower's Avatar
Old Feb 13, 2007 | 07:54 PM
NISMOPower's Avatar
NISMOPower's Avatar
Old Feb 13, 2007 | 07:55 PM
NISMOPower's Avatar
Old Feb 13, 2007 | 08:04 PM
scrhale's Avatar
talk about the slammed look ... damn. Can you get a picture of the car behind it and try to capture a lot of the street. It gives you an idea of what the car would look like if you were driving behind it.
Old Feb 13, 2007 | 08:12 PM
NISMOPower's Avatar
well i'm detailing my car and a few others tomorrow so i'll try to take some photos if it doesn't get too late. I have a detailing business i run...
Old Feb 13, 2007 | 09:31 PM
86maxima96's Avatar
I Broke OT
wow, looks great. and those parts definitely show quality craftmanship. also, great to see new products continue to be produced. especially from Brian. looking forward to hearing how they are after an alignment.
Old Feb 14, 2007 | 12:23 AM
meccanoble's Avatar
Sports Button FTW
extra sexy man, your car is looking hot. If I knew metallic beige could look so beautiful.....
Old Feb 14, 2007 | 01:57 AM
NISMOPower's Avatar
Well yeah after really looking at it today it's too low, definately will be raising it up a little....
Old Feb 14, 2007 | 04:56 AM
natty99's Avatar
Chris, love your car man. Finally got my EVO wheels, too....will be putting them on in the spring. Thanks for the idea and pics and keep up the good work with the car.
chris
Old Feb 14, 2007 | 08:04 AM
After runnning the Cattman coilovers for almost 1.5 years, I still have no squeaks or rattles. Something is definately wrong w/ your setup.
Old Feb 14, 2007 | 08:05 AM
Apparition's Avatar
Ichiban King
Damn, that looks amazing.. Cattman has been carrying different progress coilovers for a long time. Infact, I read somewhere they used to have some with adjustable dampening, but egh w/e..
Old Feb 14, 2007 | 10:15 AM
NISMOPower's Avatar
chris
Make sure you get short shank lug nuts, Honestly to say just because of the type of lug nuts that is needed I feel like buying new wheels. Don't force these lug nuts either and make sure they are torqued to spec, or you will be replacing some wheel studs. Then again I remove my wheels very often since i'm always working on the car...
Chris
