stuck in reverse
Old Feb 15, 2007 | 11:47 AM
Chris Kapinos's Avatar
LLAMA
stuck in reverse
i was backing out of my driveway after bleeding the clutch line, to take it for a ride, and i backed out of my driveway.. and now the shifter is stuck in reverse.. will not budge out.
Old Feb 15, 2007 | 12:17 PM
LLAMA
im stuck in the street, shifter will not move from reverse ,any help at all would be great. thanks
Old Feb 15, 2007 | 01:42 PM
Mxrider52's Avatar
I support for what?
Possibly air in the line causing your clutch to think it is engaged. Therefore not allowing you to get the car out of reverse. Can you push the clutch in and push the car? If not then you more then likely got air in the line.
Old Feb 15, 2007 | 01:43 PM
99BlackMaxMS's Avatar
back it up the street till you can turn around and then back it up to your driveway again
Old Feb 15, 2007 | 11:48 PM
swatspyder's Avatar
Gotcha!
Why not just drive it around in reverse everywhere he goes?...
Old Feb 16, 2007 | 04:01 PM
LLAMA
=[ i have to either get 2-3 guys to push the car 10 + miles an hour to pop it out of reverse, or pull it with a truck.
Old Feb 16, 2007 | 05:00 PM
ThurzNite's Avatar
I've had it happen in my 93 max, but it's a diff tranny than 4th gen. Sorry I can't be of more help. You can PM me or IM me if u wanna discuss it.
Jae
Old Feb 16, 2007 | 05:07 PM
KRRZ350's Avatar
Lol, I was wondering if it was badly in the street in your clutch thread, I was gonna say, your leak shouldn't be too hard to find if it's that bad, however, I would bleed it again in the street to move it back to your driveway, bleed it again and don't forget there is TWO bleeds, one on the strut tower and one on the slave cylinder, I've always bleed the higher strut tower first, unless it's a real bad leak you should be able to get it at least back into your driveway, good luck and if you're in a real bad jam and can't get a response quick enough on here call my cell and I'll guide you through
tarun900
19
Dec 20, 2021 06:57 PM
05RLS2
Apr 14, 2016 11:49 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
