clutch change
clutch change
So I finally have the money to get that clutch change, just wondering where there is a site where I can buy the whole clutch system, I heard that u can get it for $200, and what are the most important parts to change in the clutch? since I'm not all too familiar with it
I got an Exedy on eBay for $125 shipped. You get pressure plate, t/o bearing, and clutch disc. It arrived in about 2 days. Then have your flywheel resurfaced. That's the important stuff.
Ignore the pilot bushing/bearing - they should not be replaced.
Dave
Dave
Originally Posted by ethnic6
no, I refuse to buy anything mechanical from ebay, I learned my lesson and I'm ever buying parts from that site especially essential parts such as the clutch...
ebay=crap.
5th gen disk and pressure plate, and a new release bearing all the way. Cap it off with a fidanza flywheel if you want.
If you'd rather pay 2x as much for the same stuff, that's your choice.
Dave
so what I really need is the disc, pressure plate, flywheel and Throw out bearing right?
Dave
first you must think your driving style then how many whp you have right now and how many whp you plan to have on your car in the future because for most of the people here a good replacement might do just fine if you have a few mods and race from time to time a high quality stage 1 should be your choice anything above the 300whp you are looking into stage 2 and above
but do have one thing in mind some stage 2 and above are very unforgiving in stop and go traffic, i do have a great experience using a exedy stage 1 very "normal"pedal feel and a great grip even on the 275-300whp range(240sx/sr20det)
I think my flywheel is warped, so I might end up getting new ones, so how much does the Fidenza flywheel usually go for? and where can I get them with a good price?
well the reason why I wanted to change the clutch was because sometimes when I'm at a stop light I like to shift while on neutral, but the problem is that sometimes the shifter won't even go into the gear fully as if its stuck, it would only go in if I carefully release the clutch. which is kind of weird to me, and it does this on all gears, 1st to reverse. Someone told me that it was the flywheel that was doing this, so I was thinking of changing that along with the disc/pressure plates
Whoever told you the flywheel was the source of your shifting issues makes no sense. Clutch, yes, but not the flywheel.
Dave
i've found fidanza fly's on ebay, its not a scam or anything, once in a blue moon i'll see one there and they'll be like 300 ish , but new from fidanza they cost $360. like i said if you've got the money to blow do it, cause frankly taking out your tranny isn't something thats amazing fun and you might as well do as much as possible at once
ok so the checklist for me now is to change the disc/pressure plates/anf to resurface the flywheel right? I can't seem to find a throw out bearing...
Dave
You might want to do the rear main seal while you are down there. Just make sure if someone else is doing it that they don't try to charge you an ADDITIONAL 450 in labor after they have already removed your flywheel to install it.
does any one know any websites that sell the 2000-2001 maxima clutch kits?
The 5th gen clutch, pressure plate, and throwout bearing from Southpoint Nissan is $213 shipped to me in Ohio, so to Buffalo should be the same or a few dollars more. Call Dave Burnett and ask him to give you a quote.
Mar 12, 2020 12:06 AM
RWCreative
Sep 21, 2015 11:01 AM
pears
Sep 18, 2015 05:25 AM
