help air bag light flashing
hey guys yesterday my air bag light started flashing while driving my i30, i have a buddy that works at a nissan dealership and he checked the error with nissan consult, result was pass. side air bag module circut open.
can anyone give any input??
thanks
Greg
thanks
Greg
you have to reset the airbag light. you open ur doorturn the ignition on then off. push the door sensor that tells u weather the door id oped or closed. push like 7 times really quick. then turn ur car the light should be off
If resetting doesn't work you may have to replace the air bag. My friend had that problem in his Altima both air bad sensors went out so it thought they were blown he just covered the light with electrical tape
Open the door and leave open. Put the key in ignition and turn to ON but do not start. Immediately push the switch in the door frame 7 or more times within 10 seconds of turning the key to ON. Start car without turning the key to off. The light should flash slower. Turn car off and restart. The light should go off but if it comes back on you have a problem.
I've reset the airbag light on a 3rd gen and a 4th gen car with this procedure and the light stayed off.
I had something similar and I refused to pay big $$$. I tried resetting the air bag light, but could not get it reset. I then ended up looking underneath the passenger side seat. There was a plastic part that broke. I think it simply grounded the wire (assuming for the airbag). I ended up taking a plastic tie and securing it to the metal part. You can compare it to the one on the drivers side. I reset the airbag light and - voila - no more airbag flashing!
Let me know what you ultimately do!
Originally Posted by bhunter
WRONG.
EASY THERE
awesome, i will definitely check mine out, it has been on for the last 6months. and it won't reset anymore
thanks for the tip, will check it out tmw
tsi6001
10-03-2022 10:23 PM
MaximaDrvr
08-19-2015 08:20 PM
kirkhilles
08-08-2015 10:53 AM
