Oil change for 96 Cefiro 2.0 V6 : PROBLEM
Old Feb 17, 2007 | 05:48 PM
enforcer's Avatar
Hi Guys,
Changed the engine oil yesterday.
1) used the engine flush for 5-8 minutes
2) drain oil
3) change oil filter
4) Added oil
I use Castrol Magnatec 10W-40W.
Problem: The engine light is ON.
I used 4L and have just added another 1 litre.
engine light is still on.
Its quite odd as I've done this multiple times before. If I open the engine oil cap, Should I be able to see the oil as I cannot see the oil. May be i need to add more.
i can confirm there is no leak. I just drove it around a block (1K) and it runs fine, its not heating up ( needle is half way - normal i think).
Any bright ideas?
thanks.
Old Feb 17, 2007 | 06:31 PM
speed racer's Avatar
Have you tried checking the codes?
Old Feb 17, 2007 | 06:50 PM
enforcer's Avatar
nah.. I over filled the dammn thing.
Looked at he dipstick and its 1cm over H.
Should I just drain it?
RA030726's Avatar
I'm nutty for Nissans
Chances are you need a new oil pressure switch. The idiot light does nothing and by the time its on its too late, meaning you would know if it was low on oil. If you have oil in it and experience no abnormal noises you're fine.
Old Feb 17, 2007 | 08:18 PM
pmohr's Avatar
No more Maximas...
CEL or oil pressure light?
Old Feb 17, 2007 | 08:32 PM
enforcer's Avatar
i dont understand.
Its the light inside the pit, you know with the fuel light/ speedometer is.
Old Feb 17, 2007 | 11:31 PM
enforcer's Avatar
2045 hrs - drained about 1.5L of fuel.
cant check the dip stick, its dark but the light is still on :sad:
fingers crossed .. i will check again in the morning when its all settled down.
I think i may have broken a wire when changing the oil filter and thats why I like Ceaser's approach of taking the wheel off to get a clear view, will check out tomorrow.
cheers.
Old Feb 18, 2007 | 07:25 AM
pmohr's Avatar
No more Maximas...
i dont understand.
Is the symbol an oil can or a engine block?
boomerbrian
Oct 31, 2018 10:25 AM
kjlouis
Oct 3, 2015 05:29 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
coasterswim
Sep 2, 2015 07:43 AM
