Would car running lean delay trans shifting?
Old Feb 19, 2007 | 10:30 AM
0260N9's Avatar
I need help very bad. My wife has been driving my car for the past month. The check engine light came on and i had it checked at autozone. It said that I need one of the front o2 sensors and that the left bank was running lean. I finally drove the car a week later and the trans does not shift on time. The rpms go very high then it shifts. Would the car running lean cause this or should I go looking for a shop to rebuild my trans.
Old Feb 19, 2007 | 10:35 AM
NmexMAX's Avatar
dot dot dot ...
Seems more like a tranny slip than a lean condition.
Old Feb 19, 2007 | 10:41 AM
Grand_hustle17's Avatar
yep that was happening to me about 4 months ago, i say go look for the shop, i changed my tranny but the used one is doin the same, so ima try getting it rebuilt
Old Feb 19, 2007 | 11:08 AM
KRRZ350's Avatar
It's not uncommon for shifting problems to be misdiagnosed as trannsmission problems when they are not, last post could very well be a perfect example. A large loss of power will cause an auto trans car to shift erraticly. You need to replace the o2 sensor in question and see if you are still getting a lean condition, then start with changing the trans fluid (I'm assuming you already checked the fluid) and after that having a reputable tranny shop check for proper line pressure etc. Is it late to shift and you need to really force it to upshift by letting off the throttle as much as possible? Also, posting the mileage on your car is key
Old Feb 19, 2007 | 11:14 AM
yeah just about all my sensors were changed
Old Feb 19, 2007 | 11:33 AM
NmexMAX's Avatar
dot dot dot ...
is this crap :IBTL
Old Feb 19, 2007 | 11:41 AM
0260N9's Avatar
The car has 155,000 miles on it and i had the trans fluid changed today. You are correct that I have to let off the throttle to get it to change. I am going to change the o2 sensor then if the problem persist take it to a trans shop. About how much should a rebuild cost if it is needed?
Old Feb 19, 2007 | 11:45 AM
NmexMAX's Avatar
dot dot dot ...
Vtec > Vtech
Old Feb 19, 2007 | 11:48 AM
NmexMAX's Avatar
dot dot dot ...
I'm trying to keep things technically on topic at least.
Old Feb 19, 2007 | 11:49 AM
KRRZ350's Avatar
yeah I thought that's what it sounded like, that's usually an indication that the 'brake-bands' inside the trans are very worn, mileage is high also, however if it is doing it in all gears it could be a simpler hydraulics problem inside trans, either way do excctly what your planning, change o2 sensor and if problem persists find a good tranny shop, good idea might be to call all of them up and describe car and problem and ask them how much to do a 'line pressure test' find the one that gives the answer that sounds the most knowledgable. Sorry your thread got overtaken here also, this is NOT like the .org and they WILL be banned, hopefully for a long time, glad you caught my post and didn't get discouraged, absolutely ridiculous, I've reported both of there posts
Old Feb 19, 2007 | 11:58 AM
KRRZ350's Avatar
oh, forgot to add, the trans computer gives trouble codes also that can be accessed via the o/d light, they will give fault codes for many hydraulic control problems, however I've never been able to read one, they flash so damn fast and are very hard to read
Old Feb 19, 2007 | 12:02 PM
0260N9's Avatar
Thanks a lot. Will go as planned.
Old Feb 19, 2007 | 12:03 PM
NmexMAX's Avatar
dot dot dot ...
i heard you had a huge L after racing astock mercury this past saturday
Mercury Mark VIII vs DE w/ 00VI.
Check this link for reference re: tranny codes.
http://forums.maxima.org/showpost.ph...23&postcount=8
Old Feb 19, 2007 | 12:05 PM
Originally Posted by NmexMAX
Mercury Mark VII vs DE w/ 00VI.
markII ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????? whos got a markII
phenryiv1's Avatar
Mod her. Ate her.
is this crap :IBTL
REPORT this crap next time.
Old Feb 19, 2007 | 12:06 PM
NmexMAX's Avatar
dot dot dot ...
I reported it twice officer!!
Old Feb 19, 2007 | 12:12 PM
this guy owns an accord an want to come to the org and ruin it
Old Feb 19, 2007 | 12:14 PM
NmexMAX's Avatar
dot dot dot ...
Things look very clean now
Old Feb 19, 2007 | 12:32 PM
phenryiv1's Avatar
Mod her. Ate her.
Community policing wins again.
Old Feb 19, 2007 | 04:41 PM
KRRZ350's Avatar
hey that's cool, was that your dyno chart? I'm actually building a 700hp blown mark8 motor, well '96 cobra motor, same thing except forged crank, different cams, upper-intake. That's cool though, I swear just the other day I was saying to myself "I wonder at what rpm's the additional high-rpm ports open up". looks like 3250, never thought I'd find that out on the .org........
Old Feb 19, 2007 | 04:50 PM
NmexMAX's Avatar
dot dot dot ...
I'm kind of a dyno psychopath/junkie. I have literally hundreds of DJ runfiles.
Old Feb 19, 2007 | 04:56 PM
KRRZ350's Avatar
you happen to have one for a 96-98 mustang cobra that I could compare to the mark8 just for my own curiosity?
Old Feb 19, 2007 | 05:08 PM
NmexMAX's Avatar
dot dot dot ...
That I don't have Toss a search for it
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
