tranny question
Old Feb 23, 2007 | 10:23 PM
Grand_hustle17's Avatar
tranny question
can a broken transmission seal cause your tranny to leak???... here's the deal i just changed my tranny like 2 months ago and somehow it's leaking again??? doesnt shift bad or anything but im worried.
4MT
Old Feb 24, 2007 | 05:41 AM
dgeesaman's Avatar
Maintenance Monster
Manual or auto?
The manual transmissions can leak due to a damaged or old axle seal. But, if the tranny needs rebuilt, the axle will move around enough that oil will leak past even a brand new axle seal. Get under the car and grab the big rusty end of the axle near the tranny. If you can move it at all in a side-side or up-down direction, your leak could be from the worn-out tranny bearings. Most maxims tranny that need a rebuild start out exactly like this. If this is true, then get it taken care of as soon as you can. At least top off the tranny fluid. The longer you wait the more likely you will destroy the internals of the tranny. I've had good success rebuilding them right when the first show loose bearings/axle leaking, and the cost is kept down to labor and a new bearings/seals kit.
Dave
Old Feb 24, 2007 | 09:06 AM
kc10fish's Avatar
my question to you dgeesaman is "manual or auto?" you rebuilt what one? if ya did an auto - how hard and any special tools needed? i have an extra auto trans i want to rebuild.
Old Feb 24, 2007 | 03:45 PM
my bad, i meant auto... i've been talking on that is it work modding an auto thread and i kinda got into talkin about the 5sp it kinda became apartof my typing lol.
Old Feb 24, 2007 | 03:48 PM
matts95max's Avatar
I think auto is more complex, that is just what I have heard, all my experience is with manual trannies. 1st thing is to get under there and see where it is leaking from. Check both axle seals and then in the back of the tranny where your shifter linkage connects and in the middle where it bolts itself together. You need to know where its leaking from first before you can diagnose the problem
Old Feb 24, 2007 | 03:55 PM
i'm not doing the fixing but i always like to know whats the problem or some suggesions from the enthusiast so i dont get ripped off from the mechanics, i'm mechanically dumb
Old Feb 24, 2007 | 06:40 PM
dgeesaman's Avatar
Maintenance Monster
I've only done manual trannys. As far as I know, the auto trannys don't have much of a problem with bearing wear.
Dave
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
Socalstillen
Sep 20, 2015 11:46 PM
pktaske
Sep 4, 2015 08:40 AM
