Passenger door "courtesy light" stays on when doors are shut. Do i have a short?
Old Feb 24, 2007 | 04:20 PM
Jwad00's Avatar
Just like the title says guy my passenger side courtesy light on the door wont go off when all the doors are shut. Has this happened to anyone else? Do i have a short in the line somewhere or would replacing the part on the door where the bulb plugs in help? Its driving me insane!
Old Feb 24, 2007 | 05:33 PM
Maxgig's Avatar
I remember someone here having this same problem. I believe the switch on the door frame that's covered in rubber can be turned or pushed so that the light stays on. Try turning it and see if that fixes the problem.
Old Feb 24, 2007 | 06:16 PM
Big D's Avatar
i have a similar problem my passenger side light wont come on but the drive side come on need help to
Old Feb 24, 2007 | 06:28 PM
2da mizzax's Avatar
Check the bulb. Make sure hte button is not sticking.
As for the OP, try to push the button in by hand with the door open. may have to be adjusted or replaced.
Old Feb 25, 2007 | 08:46 AM
maximacruizer's Avatar
i shorted my driver side one ... i had the door open when i went to put a new bulb in (not thinking) and i oopsed and shorted it out,, now it wont work at all... i put and led 197 bulb in there and when i close the door i can see the LED light up a bit... and its realy really dull when the door is open so i assume that i shorted something anyways.
Old Feb 25, 2007 | 04:00 PM
maxima985spd
change the window switch.
Old Feb 25, 2007 | 05:57 PM
fastmax24's Avatar
its probably the door sensor on the car. same thing happend to me. either trying tighting it or loosen a bit i had to do that to maxima
Old Feb 25, 2007 | 06:00 PM
Jwad00's Avatar
What would the window switch have to do with anything?
Old Feb 25, 2007 | 06:09 PM
maxima985spd
it's connected to the door courtesy light. buy a used one for like 10 bucks just to make sure. there have been a couple thread about this on this site.
Old Feb 25, 2007 | 09:13 PM
DJ420's Avatar
Bad Mother Fornicator
It IS the window switch. That window switch assembly is also the relay unit for the entire door. Unfortunately, EVERYTHING in the door ties into it. I blew my passenger window switch by installing an LED in my passenger courtesy light backwards..
The funny thing was, if you put a regular bulb in it, it did nothing. But if you put an LED in it, it didnt light when it was supposed to, and WOULD light when it wasnt supposed to (when both doors were closed).
Long story short.. I was ONE of those 'threads'.. if it works on one side and not the other, replace the window switch on the side that dont work. You can thank us later..
DJ
Old Feb 26, 2007 | 06:40 AM
Jwad00's Avatar
DJ42o96max, thanks for the explanation. Im going to try this and see if it fixes it because it sounds like the problem. I installed LEDs but my pass one stays on all the time door closed or not so ill try the switch. Thanks alot for the help guys!
Old Feb 26, 2007 | 09:28 AM
maxprivate's Avatar
Black Lion
change your swith located by the egde of the door with the rubber housing. i got mine from courtesy nissan for $15 each, (i think) its a philpe head screw you have to remove and the switch comes right out. very easy takes about 5 min.
Old Feb 26, 2007 | 04:47 PM
Jwad00's Avatar
DJ42o96max, one more question, if it is the window switch causing this would the window switch not work? Becuase mine still rolls the window up and down no problem.
Old Feb 26, 2007 | 06:07 PM
maxima985spd
no, only part of the window switch can malfunction. in your case it's the courtesy light. come on you don't believe us???? if it doesn't work when you change the window switch, ill give you 100 bucks.
Old Feb 27, 2007 | 04:27 PM
Jwad00's Avatar
Its not that i dont believe you dude i am one that wants to be sure of things because i can recall a number of times i have been told my problem was something for sure and it wasnt and i was out alot of $$ so you cant blame me for being careful. I was just making sure that the window doesnt have to be inop. just cause the courtesy light is cause if that was the case the window switch would be ruled out. I like to be 100% of what i do before i start taking my car apart. Plain and simple. And where can i get a used one for $10? Cause i was quoted $130 for one of these damn things from my parts guy at work at the dealership i work at.
Old Feb 27, 2007 | 05:37 PM
i would like to know where to get a new window switch as well for the driver door 98 GLE
Old Feb 27, 2007 | 06:26 PM
maxima985spd
http://forums.maxima.org/forumdisplay.php?f=61
www.ebay.com
and i was told a bcm was 900 bucks at the dealer. i bought one on maxima.org for $25 shipped.
Old Feb 27, 2007 | 08:30 PM
Jwad00's Avatar
So im just looking for the power window up and down button for the passenger side (It being the side the door light is burnt out on)
Also, when i do replace this switch and things are working right again, am i supposed to keep the doors closed when i replace the bulbs? Was my mistake leaving the door open letting power get to the lights when i installed the LEDs?
Old Feb 28, 2007 | 05:15 AM
DJ420's Avatar
Yes, the window will still work normal.. making you suspect ANYTHING BUT the switch. I'm not sure if what was done wrong was installing with the door open or just the LED going in backwards. Pull the battery cable to plug it in. Pain in the ***, but.. you dont wanna buy 3 switchs do ya?
DJ
Old Feb 28, 2007 | 05:39 AM
sickmen's Avatar
My dome light and driver's side dorr light doesn't work after I attempted to put bigger bulb(stupid me). Since my passanger door light works 100% and only dome light and driver's side door doesn't work, if I change the driver's door switch then everything will work again? do i need to change the windows switch, too?
Old Feb 28, 2007 | 05:45 AM
DJ420's Avatar
The WINDOW SWITCH IS the switch you need to change.. not the little door switch that sets the dome light.. the WINDOW SWITCH. *IF* its yer drivers side that is not working properly, then replace the drivers window switch. That will fix your courtesy light problem and MAY remedy the dome light.
DJ
Old Feb 28, 2007 | 05:57 AM
sickmen's Avatar
thanks DJ... I will try to replace the driver's side windows switch.
How much do they usually cost at Nissan?
Old Feb 28, 2007 | 08:09 AM
DJ420's Avatar
$115 or so.. I'd recommend a boneyard or eBay.. or FanaticRockford on here.. he usually has a lot of parts for sale!
DJ'
Old Feb 28, 2007 | 06:22 PM
Jwad00's Avatar
Yeah i just picked one up on ebay for $10. Damn i love ebay.
RWCreative
Sep 21, 2015 11:01 AM
brichi
Sep 14, 2015 05:23 PM
johnaschon
Sep 14, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
