ECU code 0509
Old Feb 26, 2007 | 11:55 AM
ComradeJew's Avatar
ECU code 0509
Anyone has an idea what this is? Check engine light came on and thats the code that is popping out (i'll double check when I go home after class). I can't find any ref for that code... any idea?
I know that 0510 is a rear O2 code, but i just had it swapped like a month or so ago...
Old Feb 26, 2007 | 12:14 PM
Mxrider52's Avatar
I support for what?
There is no such code. You have misread the number of blinks.
Old Feb 26, 2007 | 12:15 PM
ComradeJew's Avatar
nope, there is such code and i just found its the front left bank o2 sensor that went kaput. Crap; my rear o2 sensor went kaput quite recently too. This is such a pisser
Old Feb 26, 2007 | 01:14 PM
Blackwind's Avatar
please do not post inaccurate information.
Old Feb 26, 2007 | 04:45 PM
ComradeJew's Avatar
Well this is interesting... I reset the ECU before going home and the SES did not come on... on the other hand I did notice a slight decrease in gas mileage; down from 23.2 to about 21.7
Old Feb 26, 2007 | 05:36 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
The light wont always come back on right away. And, a difference that small in gas milage is most likely just your driving.
Old Mar 3, 2007 | 08:15 AM
Nismo's Avatar
Isnt 0707 rear o2? http://vbxmaxima.8m.com/ecudecoder.html
Old May 13, 2007 | 01:00 PM
maxima_million's Avatar
I've been getting a code: 0509 but when I check it using: http://vbxmaxima.8m.com/ecudecoder.html, I see 'undefined'. I read some of the other posts that indicate it's the front (left bank) 02 sensor. How can I verify this?
I have reset the EUC and the code shows up every few months. I have noticed a slight drop in gas mileage (@24/gal local & Hwy). If I need an 02 sensor, does anyone have the part #?
Thanks in advance!
Old May 13, 2007 | 01:29 PM
andrei3333's Avatar
there are several codes for the 02 sensors, i have no time to tell u all exactly which code is what, but i had the 0902 code for rear 02 sensor heater
the ecu tells us exactly whats wrong with 02's. for me it was the heater that went. i replaced the sensor and the code never returned
PS : ^^^ maxima million, dont use that site, rather download the PDF file of the FSM for ur year of car and look it up there, its a longer way to do it but its more accurate and more descriptive. just replace the sensor or the ecu will keep detecting voltage that is our of range.
Old May 13, 2007 | 06:13 PM
Thanks for the reply. I'm looking as to where to get one of the FSM zip files. Would the 02 sensor cause the reduction in gas mileage since it's impacting 3 of the 6 valves? Any suggestions as to where to order it or the part number?
For others who are interested, here is a site for the FSM: http://jime.homeip.net/files/fsm/
Old May 13, 2007 | 06:24 PM
pmohr's Avatar
No more Maximas...
3 of the 6 valves, eh? Yes, bad O2 will cause bad mileage. IIRC a bad O2 will keep you in open loop.
Old May 13, 2007 | 07:29 PM
pmohr - I take it the open loop that allows for un-combusted fuel escaping out the exhaust and not getting recycled through the evap? I see ur ASE certified, I'm FAR from that hence my basic questions
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
