question about bose speaker....
Old Feb 26, 2007 | 08:19 PM
bkmax98's Avatar
So my front passenger speaker tends to work then cut off and then start working again. Does anyone know if this is a wiring problem or a blown speaker?
Thanks in advance...
Old Feb 26, 2007 | 08:52 PM
Tatanko's Avatar
Bacon Lover
I would say it's a wiring problem. If it's blown, it's blown, end of story, and you would definitely know if it was blown.
As to what specifically, I'm not sure. Possibly a short? Maybe a loose connector/plug?
Old Feb 26, 2007 | 11:26 PM
MaximaEvolution's Avatar
have u ever removed the headunit?
Old Feb 27, 2007 | 06:38 AM
phenryiv1's Avatar
Mod her. Ate her.
Wiring short.
Old Feb 27, 2007 | 09:16 AM
MDeezy's Avatar
remove the door panel and examine.
Old Feb 27, 2007 | 09:45 AM
ZachsMax's Avatar
Ridin' Spinnaz
Yeah...remove the door panel and look at the speaker (I doubt it's blown if it sounds good some of the time). My best guess is it's a loose wire or short. Either way, open up the door to check.
Old Feb 27, 2007 | 10:39 AM
bkmax98's Avatar
i changed my head unit a little b4 x-mas actually.
could that have caused a short?
Old Feb 27, 2007 | 10:51 AM
andrei3333's Avatar
instructions on removing front doors ? and whats the mounting depth for a 6.5" speaker in the front door
If I was to replace the front speakers should i disconnect the Nissan tweeter ? (new speakers come with tweeters installed)
(NON BOSE) sorry to be such a hi-jacker
Old Feb 27, 2007 | 11:35 AM
MDeezy's Avatar
door pannel comes off by 3 screws. another in the cup on the door handle. plus manuvering the door handle thru the opening. lift up and wiggle.
speaker is held in place by 3-4 screws. tweeter doenst need to be touched. should be mounted on the a-pillar.
Old Feb 27, 2007 | 12:54 PM
dgeesaman's Avatar
Maintenance Monster
Possibly. It could also be a loose piece of wiring.
Did you use sealed crimp connections or soldering? I first soldered mine, but soldering is crap unless you're good at it. Crimps rarely fail and they are electrically superior to DIY soldering.
Dave
Old Feb 27, 2007 | 12:57 PM
andrei3333's Avatar
I have a 97 my tweeter is in the door above the door handle
whats the deepest speaker i can put in ?
Old Feb 27, 2007 | 01:00 PM
97SEdriver's Avatar
this place is dead
The head unit to another Blows head unit, or something else. Blows head units are designed to run at a different resistance than normal car stereos, and in turn so are the speakers.
I hate by pos blows head unit and can't wait to replace it.....
Old Feb 27, 2007 | 02:19 PM
dgeesaman's Avatar
Maintenance Monster
Did you install a proper adapter? Running a standard head unit to Bose speakers will damage them. They make sound, maybe even decent sound, but they burn up.
Dave
Old Feb 27, 2007 | 04:37 PM
bkmax98's Avatar
Dave
well i took it to a car audio/alarm shop to install my kenwood head unit, and I remember seeing adapters installed. Maybe I should just take it back to that shop. Thanks for everything.
Old Feb 27, 2007 | 04:47 PM
dgeesaman's Avatar
Maintenance Monster
Yeah, definitely make it their fault. Really, unless they find a reason it isn't, it IS almost certainly their fault.
Dave
Old Feb 27, 2007 | 06:27 PM
Tatanko's Avatar
Bacon Lover
That is the absolute exact opposite of my experience.
Old Apr 4, 2007 | 12:08 PM
a few twists with black electrical tape works for me hahah
Old Apr 4, 2007 | 12:36 PM
z32drifter's Avatar
If you are still using the Bose amps to power the speakers that's you problem. The Bose amps crap out and cause a number of problems, cutting in and out is one of them. You can have your installer check their work at the headunit, but if you still have the Bose amps I'd bet that is your cause.
Old Apr 4, 2007 | 03:56 PM
dgeesaman's Avatar
Maintenance Monster
It did occur to me today that you must use crimping pliers to secure the connection. You can't a useful crimp from any other common hand tools. The combination wire stripper/crimper/cutter tool isn't very expensive and comes in quite handy.
Dave
Mar 12, 2020 12:06 AM
pears
Sep 18, 2015 05:25 AM
popdedop
Sep 11, 2015 11:17 AM
Johnny9595
Sep 3, 2015 05:18 AM
