Clicking when turning the steering wheel?
Old Mar 5, 2007 | 06:27 AM
cardana24's Avatar
Blown
What would cause this? It really only happens when I am turning the wheels when I am stopped. I will get a rapid clicking noise. Everything feels fine while I am driving. What would cause that? This is happening on my 95 GXE. Thanks for any help.
Old Mar 5, 2007 | 06:47 AM
TJShag13's Avatar
Strut bearing.
Old Mar 5, 2007 | 06:53 AM
cardana24's Avatar
Blown
Originally Posted by TJShag13
Strut bearing.
I have had those fail before and they did not fee like this. They would make the spring bind and I would have a one big pop....this is a much more rapid clicking that you can feel in the car. Whatever it is really got worse after driving my car on some really bad roads this weekend....lots of bumps and rough roads.
Old Mar 5, 2007 | 06:58 AM
max ride 41's Avatar
upper strut mount, mines been doin that since i bought my car 2 years ago. about 45.00 a side plus labor.
Old Mar 5, 2007 | 07:05 AM
cardana24's Avatar
Blown
What would fail in the strut mount that would cause it to make a rapid clicking noise when turning the wheels? How do you know that's what is wrong with your car if you have not fixed/tried fixing it?
Old Mar 5, 2007 | 08:09 AM
abomb1987's Avatar
if it does only when you turn then its you cv axle, that means the rubber boot of the axle that holds the grease either broke or just dried out
mine had the same problems and it cost like 150.00, depending where you go
Old Mar 5, 2007 | 08:50 AM
cardana24's Avatar
Blown
that does not make since to me since this happens when the car is not moving.
Old Mar 5, 2007 | 08:53 AM
cardana24's Avatar
Blown
What would a steering rack do if it was messed up or on its way out? My car is lowered on Ground Controls, currently it has a drop that looked very similar to my S-techs, but once the bad weather is gone I lower the front all the way down on my 18's. I am really hoping this is not the problem but I just thought I would throw it out there since I am not aware of what it will do when it is going out/screwed up.
Old Mar 5, 2007 | 09:22 AM
OttawaMaxima14's Avatar
I have a 1999 Nissan Maxima ES with the VSLD and when I'm driving I get the popping sound when I turn also but the other thing is sometimes when i press the gas the car kind of jumps and then it catches speed is this the axle or the transmission I have a 5 speed how do you tell if the tranny is going ??
Old Mar 5, 2007 | 09:24 AM
abomb1987's Avatar
theres a clicking noise when the car is not in motion?
Old Mar 5, 2007 | 09:50 AM
TJShag13's Avatar
I had the same rapid clicking as you are describing while turning the wheel and while the car was NOT in motion. I replaced my strut bearing and the problem was solved, the stupid little plastic bearing didn't even look bad but it was def. the source of the problem.
Old Mar 5, 2007 | 10:04 AM
cardana24's Avatar
Blown
can you please delete your post. If you post 3 more times you can start your own thread.
Old Mar 5, 2007 | 10:06 AM
cardana24's Avatar
Blown
hmmmm...ok, I will make sure I change those. I will be lowering the car back down to the summer height soon and probably replacing the struts at the same time so I will get some new bearings, even though I just put new ones in there less than 10k ago.
Old Mar 5, 2007 | 03:39 PM
i had the dealer tell me its the strut mount or the the plate thats sits on top of the strut that clicks when you turn the wheel sitting still. its not a big deal, you can replace the strut mount on just the bad side if your tight on cash.
Old Mar 5, 2007 | 07:33 PM
cditto's Avatar
Does it happen at very low speeds too? I ask because mine does what you are saying when I back out of my garage and turn out onto the street, but once in motion all is fine.
Old Mar 6, 2007 | 07:10 AM
no, its just sitting still, and its not an emergency to fix. if you feel uneasy, take it to someone you trust and let them listen. good luck.
Old Mar 6, 2007 | 01:04 PM
90stanza's Avatar
I'm going to go with Strut bearings I hope thats the problem
Old Mar 6, 2007 | 02:05 PM
MorpheusZero's Avatar
Sounds like the bearing to me (my bearings are gone too). The bearing is sometimes referred to as the mount as well.
Definitely not the CV joint. It clicks while turning the wheel and stopped, not while moving with the wheel turned.
Old Mar 7, 2007 | 05:23 AM
cardana24's Avatar
Blown
ok, does anyone know where I can purchace the ground control greasable upper mounts? They have the bearing built into the upper perch. Anyone know?
Old Mar 7, 2007 | 05:27 AM
ronnieron's Avatar
It's the CV Joint
Old Mar 7, 2007 | 05:52 AM
willard00's Avatar
i get that too. park your car with the steering wheel straight and look at your two front tires. they should look straight (like: | |) for me, my camber on the passenger front tire is off (which makes my tires look like: | \ ....that a little exagerated though). the poping would come from the tire slipping. an alignment would fix it, which is hopefully happening today for me.
you check that too. mine happens mostly at low speeds, but sometimes turning corners too.
Old Mar 7, 2007 | 06:56 AM
cardana24's Avatar
Blown
Originally Posted by ronnieron
It's the CV Joint
Could you tell me why you think that? Both axles are less than a year old. How would a CV joint cause this?
Old Mar 7, 2007 | 07:26 AM
willard00's Avatar
it wouldnt. your axles are good. theres no way theyde go bad in a year
Old Mar 8, 2007 | 02:05 PM
pj1016's Avatar
Your cv joint would click while in motion.
pj
Old Mar 8, 2007 | 03:13 PM
It's the CV Joint
You're FOS. It's not the friggin CV joint. Did you even read the thread?
Old Mar 8, 2007 | 11:39 PM
MaxiiMa's Avatar
i have a similar problem in the car, and reading thru the forums i beleive its the strut mount, not sure until it's been properly checked out, but here's what i have examined so far, when i was changing the front driver's side tire and was loosening the 5 bolts, i could hear the same knocking noise that comes when turning while the vehicle is stop or a quick turn when in motion, or while driving over bumps, and when i suddenly press on the gas paddle when the car is in motion or take my foot quickly off the paddle when picking from a complete stop... i noticed that the wheel and shock actually moved back and forth when i forced the bolts to tighten/loosen, i tried loosening the bolts on the front passenger side and everything is fine, no noises or loose movement.
i think its the mount, most members have had the same problem and have solved this problem by replacing the strut mount...
Old Mar 9, 2007 | 06:30 AM
cardana24's Avatar
Blown
Hey man, I know you are new and cannot post your own thread, but please don't do this in my thread.
If you springs are binding a poping then most likely you need strut bearings, once they break they do not allow the spring to trurn when you turn the wheel so the springs blind/flex and then pop.
Old Mar 9, 2007 | 06:14 PM
L0R1DA's Avatar
cardana24, I believe your problem will be solved with new tie rod ends and ball joints. Check for bent inner tie rods as well. Good luck!
Old Mar 12, 2007 | 05:16 AM
cardana24's Avatar
Blown
Thanks for the suggestion. I am pretty sure the problem is a strut bearing, but I have not fixed it yet. Yesterday I adjusted my suspension to nice weather height and noticed the strut bearing on the passenger side was all broken up, peices were falling out of it. I am pretty sure that is what is causing my rapid clicking but I have not had a chance to get parts to try to fix it yet. I'll report back once I get a chance to replace it, I'll try to take a picture of the broken one.
Old Mar 13, 2007 | 09:29 AM
oVeRdOsE's Avatar
Same thing here, clickinf while turning wheels and stopping.
It comes after my drop, so yeah, 90% of chance thats the strut bearing.
good luck
Old Mar 13, 2007 | 11:42 AM
vortechpower's Avatar
A good rule to follow, never turn your wheels if your not moving!
Old Mar 13, 2007 | 11:57 AM
oVeRdOsE's Avatar
Of curse we dont do that.
It cames while we running very slow ( like parking)
Old Mar 16, 2007 | 10:41 PM
99seCALIforniCATer's Avatar
I am getting the clicking noise also and a very loose steering wheel, would it be a better idea to just replace the whole strut rather than taking it apart to replace the bearing only?
Old Mar 18, 2007 | 07:45 AM
yes, unless you have new struts which i can't imagine you do if your plates are that bad. mine have clicked since day 1 and i've never worried about it. i'm more worried about the power train ........
Old Mar 19, 2007 | 05:42 AM
cardana24's Avatar
Blown
the bearing that I am talking about is not inside of the strut, so if you replace the strut and have a bad strut bearing you are not going to fix the problem.
When I took my broken strut bearing out I was able to slide it off of the top mount with out taking my strut out....it was that broken. It was in 3 peices and their was not much left. I was able to put the new bearing on with out taking the strut out either. I took the strut top nut off and pushed it through the strut mount with tha pair of needle nose pliars. Once I had it down that far I pushed it a little further and was able to push it a little bit more with my fingers, at this point I just pushed the bearing over the top of the strut then let the strut go back up through the mount (also I put my dampining on "1" before I did any of this so the strut would be easier to push down). I also took the advice of JSutter, I put some rtv on the top of the top flat surface of the bearing so that it would stick to the upper mount, so that hopefully it will stay in place and not keep breaking. My car is currently at the shop being aligned. Hopefully everything is good to go now.
trasmadean
Feb 1, 2017 08:20 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
tnewbs
Aug 28, 2015 10:15 AM
jhontelj
Aug 17, 2015 04:07 AM
Flores94
Aug 11, 2015 12:53 PM
