about to install coilovers...what should i also replace?
I just bought a set of Tein Basic Coilovers from a fellow org member and was wondering while I am at it, what else should I replace?
I have 175,000 miles, I am not sure how many miles are on the stock suspension components but I'm pretty sure they are very worn out. I figure since I am down there...might as well replace a couple of things.
So let me know what u guys think...I'll admit that when it comes to suspension...I am pretty lost.
Strut bearings for sure.
What all is included in the Tein kit? What OEM parts are reused? Mounts (as long as they show no signs of rust, wear, or fatigue) should be fine. Anything rubber SHOULD be considered for replacement, if it is re-used.
It comes with OEM top mounts, bushings and bearings. heres the link to the FS thread http://forums.maxima.org/showthread.php?t=512287
so i should replace anything rubber that is reused? like what?
and for bushings...which ones should i replace? where do I buy some good ones?
EDIT- all that I would really replace would be strut bearings in the front. Go OEM from Dave.
Originally Posted by phenryiv1
If you buy new ones, buy OEM from Dave B.
also I am thinking I should also replace my front control arm and front sway bar bushings with Energy Suspension ones and replace my worn tie rods. What do u guys think? anyone have experience with ES bushings?
Originally Posted by ewuzh
The previous owner replaced all bushings, bearings, strut mount and the thin "paper" gasket with new OEM Nissan parts just two years ago. They should have plenty of life left in them. I wouldn't think you would need to replace that stuff so frequently. The top mounts should spin without much effort. Just tryin' to save you a buck or two.
so i guess i will be replacing the front control arm and front sway bar bushings with Energy Suspension and possibly the tie rods.
anything else i should replace while im doing all this?
I've heard that replacing the LCAs might be a good idea, although I'm really not sure how much play can actually be in a solid metal part... and it won't exactly be easy. If they made forged aluminum LCAs I'd jump at 'em...
Def get ES bushings. I have the control arm bushing and felt a huge difference after install. Once i change up my suspension in the summer i'll change all the bushing to ES. Cattman is selling every bushing ES makes for our car and fairly cheap. Check out the GD section.
Team STILLEN
Aug 10, 2015 04:29 PM
kirkhilles
Aug 8, 2015 10:53 AM
MikesChevelle
Aug 6, 2015 11:36 AM
