Stuck bolts
Old Mar 7, 2007 | 02:08 PM
Pieps's Avatar
Stuck bolts
I am replacing my wheel bearing right now, and i have all the bolts out except one. I am stuck on the bolt that attaches the spindle to the LCA. I have used lots of Liquid wrench, and even tried heating it up. What else can i do to get it off, it is a PITA trying to get off. Any suggestions? thanks
Old Mar 7, 2007 | 04:28 PM
Pieps's Avatar
Does anyone know?
Old Mar 7, 2007 | 04:32 PM
LASTONE's Avatar
Is it just spinning? If so put pressure on it and that will stop it turning then you can take the nut off.
Old Mar 7, 2007 | 04:41 PM
TunerMaxima3000's Avatar
I dont know what tools/facilities you are dealing with, but I would try to whack the LCA and shock it, then heat up the area 1/2" around the bolt, and use some leverage, if you can hit whatever you're using(ratchet, wrench) with a hammer that may break it loose.
Old Mar 7, 2007 | 04:46 PM
2da mizzax's Avatar
If it is spinning then you have a problem and need to change your ball joint. If it isnt spinning, first make sure you have removed the cotter pin, take out the axle, and use a 1/2 inch drive with a breaker bar. If that doesnt get it off, it is siezed on and has to be torched or cut off.
Old Mar 7, 2007 | 07:04 PM
SNOMAX's Avatar
PM me for LCA's!
I am assuming you mean the nut on the ball joint. As seen here in my blatant rip off of the FSM:
If that is it, you need a ball join separater. Which you can get at Harbor freight for cheap http://www.harborfreight.com/cpi/cta...emnumber=38649 or more than likely borrow one for free from an auto supply store. It's pretty hard to remove it without the tool. Good luck...
Old Mar 8, 2007 | 03:22 AM
Pieps's Avatar
It does just spin when i try to take it off, so i had a friend of mine hold it while i used a 6 foot breaker bar on it. I does spin around that, so that means i need a new one? If i get a seperator, then how does the new one go in?
Old Mar 8, 2007 | 03:39 AM
2da mizzax's Avatar
you use the seperator to remove teh ball joint stud from the steering knuckle. In this instance, you can try to release the nut while someone else is prying down on the seperator. when you pry on it (assuming it has already come loose from the knuckle) the extra friction may allow you to get the nut off. Only problem is, once that stud is rotating, it is pretty much time for a new one anyhow. You can replace it with a MOOG and the same shop that is pressing in the wheel bearings will be able to press in the new ball joint.
To be sure you need a new one check for resistance when you get it out of the knuckle.
Old Mar 8, 2007 | 06:00 AM
Pieps's Avatar
Would i have to take the LCA completely out then to get the new ball joint pressed in? I just can't break the bolt loose with my friend holding the knuckle steady while i try to break the bolt.
Old Mar 8, 2007 | 06:41 AM
2da mizzax's Avatar
you can use the ball joint separator to try and keep the whole bolt from spinning. . place it between the LCA and the knuckle and pry down. pry hard enough and the bolt will stop spinning allowing you to remove the nut. problem is, when you use that tool, you can sometimes tear the boot covering the ball joint. this lets the grease out. another problem is that if you can spin the bolt using your fingers (or it spins fairly easily) the ball joint is probably worn and now is as good a time as any to to change it.
Old Mar 8, 2007 | 07:36 AM
Pieps's Avatar
If the knuckle is all the way to the left, as if the car was turning right, and i spin it to the right, the bolt on top spins with it. It does not spin loosely with my fingers, so would the seperater be any help? Is my ball joint broken?
Old Mar 8, 2007 | 09:25 AM
2da mizzax's Avatar
honest opinion. take it to a shop. sounds like you dont know enough to do the job. if the ball joint were broken the knuckle would come right off. directions on what to do are above. good luck.
Old Mar 8, 2007 | 01:05 PM
mel6822's Avatar
I had the exact same problem last month when I replaced my wheel bearings. Take a dremel-like tool and make a long deep cut on the side of the castle nut. Then insert a large flat head screwdriver in there and twist it to break it loose from the tension on the bolt. You should be able to spin the nut off after that. Good luck on it.
Old Apr 7, 2007 | 01:49 PM
silverfox1's Avatar
You can also file the nut if you don't have a dremmel or die grinder. This is a cave man approach so be careful not to ruin anything else.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
