Front Right Heated O2 sensor
Old Mar 9, 2007 | 06:15 AM
4thgenlewis07's Avatar
I read the codes off my ecu and it gave me an 05 03 which is the; Front Right Heated O2 sensor, it also gave me an 01 02 which is the; Mass Air Flow Sensor. I believe it gave me the Mass Air Flow Sensor code b/c I had unplugged my Mass Air Flow Sensor and plugged it back in when fixing my intake. Anyways I have reset the ECU and the engine light has not came back on. Should I wait and see if it comes back on, or should I go ahead and replace the Front Right Heated 02 sensor? Thanks
Old Mar 9, 2007 | 06:33 AM
Zero-K's Avatar
VQ30DET
It's not going to hurt it any by waiting to see if the CEL comes back on. When it does, then go ahead and change the sensor, and reset the ECU again. It is possible that something happened and thew a code for no reason, so no since paying the money out now if you don't need to.
Old Mar 9, 2007 | 07:07 AM
Thanks Zero-K, will do!
Old Mar 9, 2007 | 07:52 AM
ComradeJew's Avatar
If you have an OBD2 scan tool, or someone that does - you can measure the voltage of the sensor. If its below 700 mv while driving - it is toast.
rbuswell
Nov 12, 2016 04:11 PM
homeyclaus
Sep 3, 2015 06:15 PM
Alberto10mg
Aug 25, 2015 12:54 PM
FlaMark
Aug 21, 2015 11:06 AM
