Should I expect better 1/4 from vlsd 01 ae trans?
Old Mar 9, 2007 | 02:47 PM
smotz's Avatar
Brain phuck
Ok after my car being down with the tranny ripped out at the shop for almost a month, the nightmare is finally over!
My original search for a vlsd after a week turned up dry. So I told the shop to rebuild. They ordered the parts needed. 1/2 of them got shipped to the wrong address. After they finally received the parts (I had to track them down and recover them) they find out the gears won't fit! So I do a quick search for a vlsd and bang! 01 AE trans for $1050. I pick that up and now I am vlsd equipped. New stock flywheel and new 01 factory clutch. Trans shifts great and the clutch feels fantastic. Nice soft peddle and nice soft smooth shifts.
Now the question is, will I get better launches with this vlsd at the track?
Last year my best and last run was 14.02 @ 101 with a 2.27 '60 time on mazda mil wheels with bfg drag radials on them on my open diff trans spraying 75 shot 1st-2nd-3rd-4th.
Any guesses what I will be able to muster this year when I track her for the first time in April?
I will be using the same mazda mil wheels with the same bfg d/r on them.
Only change to the car will be the fidanza flywheel > New Stock flywheel, Stage 3 clutchmaster clutch (I know, I know.. stupid kids) > 01 oem clutch, and the awesome VLSD 5 spd trans.
Old Mar 9, 2007 | 03:47 PM
96blkonblkse's Avatar
Probbaly wont change much. You should be able to get a better launch, and perhaps heat up the slicks equally, i know some people complain with open diffs only 1 wheel spins, therefore 1 slick is nice and hot, and one is cold.
With slicks you should be able to cut a lot better then 2.27 60ft. 2.0 60fts shouldnt be out of the question. Are you spraying out of the hole?
Old Mar 9, 2007 | 04:04 PM
Cdg2125's Avatar
probably won't see much of a difference. Can't hurt tho right?
Old Mar 9, 2007 | 04:11 PM
NmexMAX's Avatar
dot dot dot ...
Any LSD has no affect in straight line acceleration. I only helps in autocrossing so you wont annihilate your inner tire.
Old Mar 10, 2007 | 09:04 AM
RA030726's Avatar
I'm nutty for Nissans
Nope, heck it could slow you down a bit since the diffy is bigger. I didnt notice any benifit at the strip, but it shines when cornering hard.
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
uttadms31
Sep 30, 2015 05:24 AM
Marc2theMax
Sep 28, 2015 08:13 AM
