Hids
Old Mar 9, 2007 | 12:03 PM
maxiquin's Avatar
Hids
Where is the write up to install them? With pics would help too and yes I did look around...
Old Mar 9, 2007 | 12:09 PM
Lumberg™'s Avatar
on this site too damn much
are you talking about a plug and play kit or projectors? gotta be a little more specific
Old Mar 9, 2007 | 12:12 PM
99grnmaxgxe's Avatar
I heard it's really easy.
Old Mar 9, 2007 | 12:52 PM
maxiquin's Avatar
How to hook up the ballast...the wiring....ive already read the sticky to building your projectors and such but it doesnt say how to wire them??????????
Old Mar 9, 2007 | 12:57 PM
jaep0913's Avatar
if u got a kit, you should of gotten the installation instruction.
Old Mar 9, 2007 | 01:10 PM
maxiquin's Avatar
i just want to see a write up and pics before i buy one...
Old Mar 9, 2007 | 01:49 PM
icedout's Avatar
? its plug and play there not much more to say....???
Old Mar 9, 2007 | 02:00 PM
maxiquin's Avatar
i thought the wires go to the battery terminals or something? any pics? of the hooked up?
Old Mar 9, 2007 | 02:45 PM
aznstormin's Avatar
I just installed mine last weekend. It plugs into the socket the headlight uses. Then the ballest and harness and bulb connect to each other. Nothing to the terminals unless you're using a relay? Or something like that. But PNP...simple as that. You just need to find some space for the ballasts. If I have time I can take pictures...but that might not be until tomorrow.
Old Mar 9, 2007 | 04:07 PM
Cdg2125's Avatar
You didn't answer his question. Projectors are not as easy to wire up as HIDs. HIDs plug right into the stock harness, it's pretty self explatory. Look at your lights and the HID harness you got. Go from there. If you're talking about wiring projectors then go to HIDplanet.com or search around because there is a big thing about how to wire them up in here.
Old Mar 9, 2007 | 06:21 PM
ethnic6's Avatar
I just got the new R34 that comes with the HIDs, but it never came with an instruction.... sooo ya I need to know how to put this in too
Old Mar 9, 2007 | 09:34 PM
Cdg2125's Avatar
what new r34 with hids?
Old Mar 9, 2007 | 09:41 PM
maxiquin's Avatar
these are what im talkin about..http://cgi.ebay.com/ebaymotors/JDM-N...QQcmdZViewItem
Hids kits come with all this and they are still plug in play? If so then I guess I'll give it a go.
Old Mar 9, 2007 | 10:02 PM
Cdg2125's Avatar
yeah you really should try getting them in there before asking how. See what you can do and if they don't work, I'm sure someone can help you out here.
Old Mar 10, 2007 | 01:31 AM
ethnic6's Avatar
the new one piece headlight that comes with HID setup, I believe I"m missing the bracket to install the ballast, so I'm wondering what I can put the ballast cause I don't want the thing to just hang...
Old Mar 10, 2007 | 01:54 AM
2da mizzax's Avatar
you dont wire up projectors. projectors are the lenses/housing. you wire up the HID ballasts which either come with adapters that allow it to plug into the original harness for power or you have to tap into the positive and negative. no need to run anything to the battery.
Old Mar 10, 2007 | 10:31 AM
Cdg2125's Avatar
my bad. i was under the impression the wiring was different for projectors. I know that projectors are the lenses and ballasts, I just assumed the wiring for the projectors hids was somewhat different since people always b!tched about wiring them. I never put two and two together because most hids are plug and play anyway.
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Mochedda
Dec 15, 2015 11:27 AM
Vistance
Sep 17, 2015 05:17 AM
MidnightMaxima_22
Sep 12, 2015 06:02 AM
