What could this noise be??? (3rd time posted no help)
Old Mar 9, 2007 | 06:37 PM
Luisjo's Avatar
Hi, i have a rattle style noise from the front passenger side, only when i accelerate and rpm hi (between 900-1300) and is really anoying, i bought it without this noise and is louder every month or so, ive had this problem for 4 months now and haven't figured out i will post a video tomorrow before 2 PM. I will send it to a mechanic but i wanted to know if someone had this problem before. Thanks
Old Mar 9, 2007 | 06:53 PM
maximacruizer's Avatar
i dunno about the passenger side, but i know on the driver side my VIN # rattles maybe its something in or behind the glove compartment?
Old Mar 9, 2007 | 07:04 PM
Luisjo's Avatar
i dont think so is on the engine. thanks anyway since i didn't got much help the other times i posted
Old Mar 9, 2007 | 07:23 PM
maximus_pr's Avatar
read this tsb
http://www.jatan.net/tsbs/041296.pdf
Old Mar 9, 2007 | 07:25 PM
Maybe its around where your belts are... the tensioner ? i unno
Old Mar 9, 2007 | 07:55 PM
maximus_pr's Avatar
does it make the noise while cruising or just accelerating,how about when the car is idling it happens when going straight or when cornering can you describe the sound
Saludos!
Old Mar 9, 2007 | 08:04 PM
Luisjo's Avatar
Saludos!
que hay pana...well the sound only comes when i accelerate from being still, when im running (between 10 and 15 MPH) i sounds again, when i am cruising, idling theres no sound, haven't tried cornering though
Old Mar 9, 2007 | 11:03 PM
pocketrocket's Avatar
do you have an aftermarket y-pipe? shot in the dark but could be a mild bees in the can sound since it's only apparent low-speed/level acceleration.
Old Mar 9, 2007 | 11:14 PM
Luisjo's Avatar
nope i have the stock Y pipe, btw i just realized that at startup (cold) the car makes this awful noise for like 3 seconds (it sounds like a fast hammering) pretty loud too.
Old Mar 9, 2007 | 11:29 PM
Originally Posted by Luisjo
... i just realized that at startup (cold) the car makes this awful noise for like 3 seconds (it sounds like a fast hammering) pretty loud .
Sounds like a worn timing chain tensioner. Happens only in cold weather, with cold engine? If it isn't there on warm engine start and goes away with warmer temps, I believe "putting up with it" would be your cheapest solution
If it gets worse, then there's a bunch of other threads about timing chain tensioner replacement that you can search for.
Old Mar 9, 2007 | 11:30 PM
Will wait for your video post about noise, I am sure it will help.
Old Mar 9, 2007 | 11:31 PM
Hondawhat?'s Avatar
is it a rattle or a vibration?
After I lowered my car I have a vibration from the right front on accel between 20-30 mph and 60-up. While I was lowering the car the axle came apart inside the inner boot so Im sure its the axle but mines a vibration so I dont know if its the same problem. Good luck
Old Mar 10, 2007 | 09:51 AM
Luisjo's Avatar
Heres the video!: http://video.google.es/videoplay?doc...27871001881712
The first 5 seconds is when the hammering noise is strong, after the first 5 seconds you can still hear it alittle bit until 14 seconds, at 16 second i put my car in Drive (to get the rpm's exactly where i want them) then at the end (25+ seonds) the sound dissapears, the sound will come back if i hit the gas pedal till 800 rpm's (if im still) if im driving then it's (800~~1300)
BTW, the starting sound (first 5 seconds) started when my car was burning oil (if that helps) theres oil in the car so is not that, but maybe close?
Old Mar 10, 2007 | 10:30 AM
Concord's Avatar
Obviously something related to the engine.
Why dont you try and isolate the noise;
Remove AC/Alternator belt-Is noise still present?
Remove PS pump belt-Is noise still present?
If noise is still present with both belts removed it's something internal
Old Mar 10, 2007 | 10:41 AM
Luisjo's Avatar
i will try that, thanks although not today since i have a university project, but will try that before monday
Old Mar 10, 2007 | 02:36 PM
gunny11218's Avatar
thats what mine was doing, i say get under your car and see if there is a heat shield that is broken and/or falling off because that will make a really annoying high pitched squeeking sound when going over even the smallest bumps
Old Mar 10, 2007 | 06:32 PM
maximus_pr's Avatar
my advice is to take your car to a reputable mechanic and have the car check properly
Old Mar 10, 2007 | 06:59 PM
Maxgig's Avatar
I'm not a mechanic but to me your car sounds like you may have had an oil problem ( ie: drove when it was low) and damaged something. It sounds like a cold diesel truck, I recommend getting it looked at by a mechanic before it gets worse, which I believe it might. Keep us posted.
Old Mar 10, 2007 | 07:21 PM
Luisjo's Avatar
i already talked to my mechanic and will give him my car on monday, ive never drive the car low on oil i always checked it but it sounds ugly, ah BTW today i was driving and noticed my car is still burning oil so i will not touch that car till monday when i drive to the mechanic
Old Mar 11, 2007 | 05:21 PM
mmiles's Avatar
The video really helps...
I just found the same issue on my car today. it sounded just like a deisel engine... It made the same sound on a cold start up, and went away after it warmed up. I was able to make the sound come back after it was cold but reving then engine for 5 seconds or so, and when it would go back down to normal Idle you could here it for a few seconds... but it was more faint then the first time i heard it on cold start.
A good friend of mine who is a european car mechanic thinks it could be the timing chain issue, but he thinks its too soon for the timing chain to be bad the since it has only 113k on it. He explained to me that the sound could be there when its cold because things have not expanded so the chain will be looser... With that being said, it's just a guess... We are going to see if it happens again tomarrow and listen to it with a s***hascope(sp?)...
I will keep you posted on what we find...
Old Mar 11, 2007 | 05:30 PM
maximus_pr's Avatar
sound quality is kind of bad but sounds very much like a bad connecting rod bearing but what got me thinking is that you say that it goes away after a while and bad connecting rod bearings noise its constant and increase as rpm increase
my bet is something related to to engine valve train or timing chain
Old Mar 11, 2007 | 06:00 PM
el_muchacho_qc's Avatar
The first 16secs it's the valves we're earing. It sounds exactly like when I started mine a cold morning without noticing my oil pan leaking all over the floor. Check oil level when engine cold, check for leaks or anormal oil burning. Could well be realted to timing chain area.
Old Mar 11, 2007 | 07:58 PM
mmiles's Avatar
My guess is timing chain issue, when i get close under the hood, it is coming from that general area...
Sounds just like the chain hitting the case sealing the timing chain... I will find out tomarrow when we listen with a scope....
Old Mar 12, 2007 | 11:21 AM
foxracing12's Avatar
Timing chain. Anyone done the water pump? Well if you remove the tensioner, after everything installed it sounds like that for a minute while the timing chain regains tension. You probably need a new timing chain tensioner or chain itself. Make sure the car has enough oil or take it to a mechanic...
Old Mar 12, 2007 | 06:39 PM
skoobahead's Avatar
My money is on the timing chain tensioner
Old Mar 12, 2007 | 08:29 PM
killerVQ30DE's Avatar
mine makes that sound at startup for about 5 or so seconds when started from cold 80% of the time... I have 258km's on the clock so to be expected I guess .. hopefully I can safely ignore it if just tensioner
Old Mar 12, 2007 | 08:51 PM
Luisjo's Avatar
didn't gave it to the mechanic today, will take it tomorrow though my car had 130,000 and i think that is not much
Old Apr 3, 2007 | 05:35 AM
mmiles's Avatar
Luisjo - did you ever find anything out on this problem? was it the tensioner?
Hondarydr
Dec 30, 2024 06:15 PM
Matt93SE
May 24, 2019 02:58 PM
Starrider
Sep 17, 2015 07:26 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
carlosvq30
Aug 17, 2015 11:32 AM
