In the middle of changing Knock Sensor, need help
Originally Posted by kcryan
haha wish i had known that, i just snapped it, it still appears to work though
Mdeezy,
How did you get to the KS? Did you use an extension or did you try and get your hand i there? I thought about removing/moving all the fuel lines and wired that are blocking the entrance to the KS, but decided that would be too much work.
Whatever you do, do not over tighten the knock sensor. Nothing would be worst than over tightening a new knock sensor for it to crack or get damage. If all is good, you can check your ECU for codes and if you had only the Knock Sensor (0304) code or not.
sdotcarter
Sep 2, 2015 09:53 PM
