Spark plug problem...need advice (how to fix)
Old 03-11-2007 | 10:03 PM
Scott LaRock's Avatar
I changed my spark plugs but in the process, I kinda broke one of those black coils that go over the plug... I broke it right in between and the spring shows in the middle...
Car runs kinda rough because of this, please advice on how to fix...
thanks.
Old 03-11-2007 | 10:16 PM
Cdg2125's Avatar
you can't fix it. You broke the coil. It's not going to fire the cylinder correctly. You need a new coil. How did you break it? All you do is pull it out.
Old 03-11-2007 | 10:44 PM
Where can I get a coil from and how much?
Old 03-11-2007 | 10:56 PM
abomb1987's Avatar
if you broke one of the three in the front here is the link
http://cgi.ebay.com/ebaymotors/95-99...em130072155849
if you broke one of the three in the back here is the link
http://cgi.ebay.com/ebaymotors/95-99...em130072155871
hope this helps
Old 03-11-2007 | 10:58 PM
thanks alot, kinda expensive but my fault.
Old 03-11-2007 | 11:04 PM
abomb1987's Avatar
crap happens right , if you have time, go to a junk yard, they will let you get them for like 10 bucks (maybe cheaper), but i wouldn't drive with a cylinder misfiring, could mess up your new spark plugs..maybe even more
Old 03-12-2007 | 12:12 AM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
His new spark plug is going to get gas on it and his car will run rough, but nothing bad will happen. I drove for two weeks with a cylinder not fireing because I was too lazy to fix it.
mvm062
11-30-2020 09:00 AM
JoshG
51
09-21-2015 10:41 PM
14GmMax
09-19-2015 11:32 PM
Quick Reply: Spark plug problem...need advice (how to fix)
