Front Brake Question
I am changing my fronts Pads/rotors. I inspected them last month and noticed the Anti Rattle Springs were busted . Do I need to replace these Anti rattle springs. They go over the brake pads. I think that is what they are called it is a 1999 maxima.. Thanks .
Hi,
Have any of you guys came across on the big brake kit upgrade? I previously read that the kit contains the: '92 Nissan 300 ZX TT Front Calipers (4 Piston), Caliper Relocation Kit, Mustang Cobra Front Rotors (13 Inches), Steel Braded Brake Lines, HK hub-centric kit and a few home depot bolts and washers..
If so, is there any posts or threads here or mainly a write up? I am so new here and am struggling of researchin posts..mainly bcoz I think i'm a newbie and have limited search rights. Can anyone of you send me links to these posts. I found MAXRB8 at car domain - write up and this user listed a couple of names here on the org. jeff92se and matt at blehmco@ maxima.org.
Thanks Much
Whoadie
Thanks Much
Whoadie
pad retainer clips need to be in good condition so the pads can slide. lube them with caliper grease.
as for shims -- they are just there for noise reduction, and most brake pads come with them (except, of course, OEM pads). no need to buy new ones from Nissan, they are a rip-off. 3M sells adhesive ones for $5/axle and they work just as well.
yes its the anti rattle springs not the shims.
They were rusted out and i tossed them out while replacing the front break pads on a trip in Wash DC. Auto zone pads. Hate em but did it in a pinch. Going to change everything Brem rotors / akabono pads. I guess I will go to dealer and get a pair of the springs. thank you.
you certainly don't need them, but if you insist on using them don't pay dealer prices (if the dealer even sells them??). just get a hardware kit at autozone or napa for a few bucks. it should have them, along with new pad retainers (which install in the caliper braket). I personally don't use those little springs, and have never had any brake noises.
also fyi -- for the rear brakes nissan does sell a combination pad retainer & pad return spring kit that installs in the caliper. it was part of a brake TSB for 4th gens. those you may want to get as the back brakes are more prone to rattling.
I don't recall anti rattle springs either. The akebono pads include the shims. I have the brembo blanks and Akebonos from tirerack. I've been pleased with their performance, price, and longevity.
Instead of bumping your older thread, you should flush the fluid. I also would suggest buying the bolt to pop the rotor before you are tempted to use one of the bolts you've just removed from the car and strip it .
+1 for flushing brake fluid... and +1 for ditching the V-shaped "spring" that don't even come with the higher-end pads (HAWK, AKEBONO, ETC.). These pads don't even have the holes drilled for them, so that should tell you SOMETHING.
03VQMAX
09-25-2015 04:19 PM
MAXSE5SPD
08-23-2015 12:06 PM
Jcof88
08-03-2015 10:43 PM
