Who had to change O2 sensors from getting a Y-pipe?
Old Mar 19, 2007 | 01:25 PM
devilz05's Avatar
Shift_3.0
It just came to my attention that in the process of changing your Y-Pipe you can easily damage the sensors because they are so old. Has anyone come into this problem and how likely is it that I will need 02 sensors as a result. I have a 99' with 100k on the clock.
Old Mar 19, 2007 | 01:38 PM
heynow's Avatar
I'd say that you might wanna change 'em, simply becuase it's time. 2 of 'em are rated for 60Kmiles and one (behind the cat, i think) is rated for 100kmiles.
Old Mar 19, 2007 | 02:06 PM
Dave H.'s Avatar
I'd wait to change them. Be careful when you do the Y-pipe, get the correct tools for taking the O2's out since there isn't much room with the stock y.
No reason to change something that is working correct. Besides, when they do go out, it's really easy to change them with the aftermarket y, tons of room.
david
Old Mar 19, 2007 | 02:21 PM
Mxrider52's Avatar
I support for what?
Yea I would wait. I replaced my y-pipe and yea the front one ended up going bad shortly after. And it is real easy to replace them with an aftermarket y. I changed mine in 5 min.
Old Mar 19, 2007 | 03:22 PM
99se5speed's Avatar
SHIFT_up
same exact thing happened to me.
Old Mar 19, 2007 | 04:27 PM
Maxi98se's Avatar
Me too . . .
Old Mar 19, 2007 | 04:33 PM
MDeezy's Avatar
that is not true, the o2 sensors aren't fragile parts, but if your rough enough you can damage the part(s).
Either take out the o2 and take off your y-pipe, or if its too trouble some, just unplug the o2 sensors and make sure the cable isnt zip died down, then take off the y and take the o2s out when the y is off the car.
Old Mar 19, 2007 | 05:07 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
i do but i havent done it yet....
Old Mar 19, 2007 | 11:15 PM
Eric425's Avatar
i did. Busted both of them, actually.
sdotcarter
Sep 2, 2015 09:53 PM
