My Maxima lags like 56K, i think i know whats wrong
Mar 26, 2007 | 04:32 PM
When i step on the gas my car is soo sluggish and it also idles at 2K rpm i whent to the mechanic he told me i need to replace the Idle Control Valve, found one for 178$, i nkow its not my knock senosr or my 02 senors those where all replaced and i replaced the PVC valve if its not a ICV im thinking it could be the EGR temp sensor or somthing. what you guys think.
Mar 26, 2007 | 04:53 PM
dont replace the IAC Valve. Clean it first. and the TB. use new gaskets. Check/change your plugs and make sure they are gapped properly. You could also do a piston soak to ensure deposits arent robbing you of compression. either a piston soak or a Redline SI-1 fuel treatment (slow safer choice).
