CEL after installing non cat test pipe?
You sure will get the cel. You need to go on ebay and get a resistor mod for the rear O2 sensor. THis is what i did and it works. Only like 10 bucks.
Do a search for "o2 bypass" this is what i came up with.
http://cgi.ebay.com/ebaymotors/Oxyge...spagenameZWDVW
You will need to cut and solder wires. Make sure you get shrink tubing.
![](https://maxima.org/forums/images/smilies/support.gif)
I cant speak 1st hand for a max but generally on most any OBD-2 equipped cars removing the cat will cause a light. Some will run the 02 sims to trick it incase you live in a increasingly **** state where if you have a SEL light, you do not pass inspection. Ahhh New York.
edit - wow, check out the post times^
on accord's and acuras, i had soemthing called 02 sim...what it does is basically the resistor mod that tberg was talking about...it costs around $65 for it. But i'm not sure if they made ones for nissan..
Funny, on the post times. I am teaching night class and the students are doing there projects, i'm bored. So i like to answer peoples questions. I love helping people with there car problems. People helped me out here, so its my way of paying it foward.
I just got mine from cattman and it was 36 dollars shipped. Looks like a pretty simple thing. Anyone know what gaskets to use with the budget test pipe? The ends look a little bit different than the ones on my cat? thanks
Zack
Zack
MaximaDrvr
08-19-2015 08:20 PM
