$135 For Front Right O2 Sensor?
Old Jul 9, 2001 | 08:59 PM
190hpKiLLA's Avatar
Granny Driven
Did i get ripped off or what, because every one was telling me it was cheaper. And how many of them are there, bacause the dealer had truble understanding which one i need. Thanks.
Old Jul 9, 2001 | 09:08 PM
RBa's Avatar
RBa
The sensor itself shouldn't cost more than $60.. The rest was probably for labor...
Old Jul 9, 2001 | 09:13 PM
emax02's Avatar
I just bought a rear heated o2 sensor for $85 and put it in my self. I bet Courteusy Nissan whould sell the sensor for like $60-65.
BEJAY1's Avatar
Conecarver
Depends on the dealer and the O2 part. I paid $119 for a rear sensor - and that was after a 20% discount coupon!
Old Jul 9, 2001 | 09:22 PM
Daniel B. Martin's Avatar
Most 4Gen Maximas have three Oxygen Sensors. There are two "front" Oxygen Sensors, one mounted in each branch of the Y-pipe. There is one "rear" sensor mounted just downstream of the Catalytic Converter. The Engine Control Module (the computer) uses the signals from the two front sensors to control the fuel mixture. When the front sensors are operating normally the rear sensor is used only to monitor the performance of the Catalytic Converter.
As soon as you tell the dealer "Front Heated Oxygen Sensor, Right Bank" he knows everything he needs to know. $135 sounds like the right price for a Nissan part, installed (considering that you live in a high labor cost location). You can buy a Bosch Oxygen Sensor from a parts store for about $80. You can buy a Nissan Oxygen Sensor for even less from one of the Nissan dealers which sells factory parts at a discount, by mail order. A list of these dealers is found in the Sticky titled 4th Gen Maxima Maintenance Items.
Old Jul 10, 2001 | 12:16 AM
Chunger's Avatar
My other car is a Hybrid
FYI - the NISSAN O2 sensors I bought to replace my old ones were stamped with "Bosch" as well... the new ones had a slightly different design though...$65 each for the front 2 sounds about right...
Old Jul 10, 2001 | 12:44 AM
vmok's Avatar
I paid like $70 something each not installed. Be sure to state the left or right front as they are different (well, ok, same sensor, two different part numbers, two different lengths for the wire that goes from the sensor to the harness.
-V
Old Jul 10, 2001 | 07:51 PM
190hpKiLLA's Avatar
Granny Driven
Just checked my reciet
They charged me $119 and i instaled it for $40 from my mechanik. Also i showed them the print out from this page on which sensor i need and they still had trouble understanding. I guess they didnt want to mess up. The sensor fit nicely, but mechanik sad if the same code comes on again we will put it in defferent place.
The code 0903 vent controll valve, i checked it wit 12v and it worked, so i used wd40 and air to clean it because thats one of the codes that pops up.
1)Could it be NOT the valves fault but the box because the valve worked good.
2) my comp is bugging out and i should pull out the bulb and drive untill notecible things start breaking
Old Jul 10, 2001 | 08:27 PM
Re: Just checked my reciet
... 1)Could it be NOT the valves fault but the box because the valve worked good. ...
Things you can do...
1) Ask your dealer if there is a "campaign" which authorizes them to replace the EVAP Canister Vent Control Valve at no cost to you.
2) Check the condition of the wires and hoses which connect to the the EVAP Canister Vent Control Valve.
3) Remove the EVAP Canister and dump out any accumulated water.
... 2) my comp is bugging out and i should pull out the bulb and drive untill notecible things start breaking
This is the "Ostrich Technique". It doesn't fix anything and is not recommended.
Old Jul 11, 2001 | 01:22 AM
global_threat's Avatar
dayum! i tore up my bpipe o2 sensor a few days ago and just bought a new one...155 bucks. wtf, did i get TOTALLY ripped or what? not like i had much of an option, either pay it or dont drive for a week...not a hard decision.
casey
Old Jul 14, 2001 | 03:51 PM
190hpKiLLA's Avatar
Granny Driven
I asked the dealer about the campaign, and they sad it it only good for 95-96 maxima. i fixed the vent (0903). It cost less then i thought. 50 for valve and 35 for canister.Instaled it my self. My 1st gear is a little tight
just now it happend. I dont know how bad it will be later today.
Old Jul 14, 2001 | 05:10 PM
Sprint's Avatar
I just paid $62 for my O2 sensor yesterday
rbuswell
Nov 12, 2016 04:11 PM
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
sonic7
Aug 20, 2015 12:23 PM
