97 max passed emissions test but failed MIL/Check Engine light
Old Mar 29, 2007 | 01:49 PM
97MAX2NV's Avatar
Anyone know why this to happen?There is no Check Engine Light On. I was told to drive the car for a good 30 miles and a steady speed so the computer can reset? Can i just reset the ECU? Any Help would be great.thx guys
Old Mar 29, 2007 | 01:51 PM
MaximaSpd85's Avatar
if u failed b/c of a code but have no cel on then maybe u have the knock sensor code. check your codes to see which one you have. the procedure for doing so is in one of the stickies. you can also erase the codes yourself, takes a minute or two with a flathead screwdriver.
Old Mar 29, 2007 | 01:55 PM
97MAX2NV's Avatar
i replaced the knock sensor about 2yrs ago.thx for your help
Old Mar 29, 2007 | 02:08 PM
Cdg2125's Avatar
did you change the knock wire? That can cause problem too. I had my ks code after a new ks until I changed the wire.
Old Mar 29, 2007 | 03:02 PM
99BlackMaxMS's Avatar
Where can you get a wire and about how much does one cost?
Old Mar 29, 2007 | 03:26 PM
MorpheusZero's Avatar
Have you reset your ECU recently (disconnected the battery or anything)? If so, it needs a bit to drive around before it's ready to report anything. If they told you to go out and drive some more and come back, then it's probably because you didn't give the ECU enough time to monitor its signals and/or throw codes. I can't remember how long it takes, I remember it being around 200 miles after you reset the ECU.
If this is the case, just go back in a week.
Old Mar 29, 2007 | 03:27 PM
97MAX2NV's Avatar
no i just replaced the sensor.. If i reset the ECU would it not show a CIL?
Old Mar 29, 2007 | 05:31 PM
2da mizzax's Avatar
you probably have no bulb in there. do you see the CEL on when you first start the car? It is more like 150 milesat a steady pace to reset the computer, or drive through a certain pattern that tests all of the systems.
Old Mar 29, 2007 | 08:38 PM
97MAX2NV's Avatar
i think im blind cuz i cant find on to reset the ecu in the stikies
Old Mar 29, 2007 | 08:41 PM
the one that reads fault indicator something...second from last stickie
Old Mar 29, 2007 | 10:07 PM
97MAX2NV's Avatar
i know whre its located but i need to know one how long to the left then right and so on. i did it once but just cant remember
Old Mar 29, 2007 | 10:29 PM
andrei3333's Avatar
yeah mizzax mentioned a good point, make sure the actual bulb is working fine before doing anything else, takes like half a microsecond
Old Mar 29, 2007 | 10:56 PM
97MAX2NV's Avatar
ya the bulb works fine... lights up n all. its just not on when the car is on
Old Mar 29, 2007 | 11:07 PM
wen u turn it to the left, it should hit a stop, pause for a second, then turn to the right until it hits another stop then immediately turn to the left, wait a second, then turn to the right(clockwise), that should erase it, to check the code it would be half of those steps i just gave you...
Old Mar 30, 2007 | 10:45 AM
Where can you get a KS wire?
Cause that could be your problem if your KS is new.
Old Mar 30, 2007 | 12:00 PM
MaxiiMa's Avatar
rotate clockwise till stops... wait 2 secs... rotate counterclock...
start the engine... wait 2 secs... turn it off and wait 5 secs so the power to ecu drops... repeat step 1... I read it somewhere in the sticky's that if u turn the car on inbetween step1 and step2 it's a complete reset... clears emission related codes...
i have the bitmap which explains this but don't have the time and energy to look for a free pic host... so if ne1 want's i can e-mail it to them and they can post it....
Old Mar 30, 2007 | 03:05 PM
97MAX2NV's Avatar
thx dude.......after i do this how long should i wait till i got back and test again?
Old Apr 3, 2007 | 01:21 AM
Max96-97's Avatar
You can also look up your owner's manual (toward the last few pages) for drive patterns that could set your vehicle's status monitors ready. In California, you could pass smog with a maximum of two monitors not ready while all other things are OK. Many smog stations offer free re-test(s). When you go back, ask them to check the status monitors with scan tool before testing.
Old Apr 3, 2007 | 08:01 AM
maxima92se's Avatar
You dont fail because of the knock sensor. The system must have not been ready. Take it to like autozone and have them pull your codes and see if the system is ready or not.
doobadoo
Aug 15, 2015 06:43 PM
Flores94
Aug 11, 2015 12:53 PM
PhalC1
Aug 5, 2015 02:36 PM
bassmann
Aug 3, 2015 07:53 PM
