dynomax super turbo muffler
Old Mar 29, 2007 | 03:37 PM
black95max's Avatar
hey guys what dynomax turbo muffler do i need for my 95 max? they have two that are 2 1/2 inches that ive seen. any help thanks
Old Mar 29, 2007 | 04:12 PM
f550maranello2's Avatar
dont get it it sounds like garbage... especially if u have a y pipe
Old Mar 29, 2007 | 04:18 PM
black95max's Avatar
i heard one in person. sounded pretty good acually. what would recamend
Old Mar 29, 2007 | 04:26 PM
do u have a y pipe?
Old Mar 29, 2007 | 05:30 PM
ethnic6's Avatar
the best set up for our exhaust would be Cattman, no other brand can beat it
Old Mar 29, 2007 | 05:31 PM
Chunger's Avatar
My other car is a Hybrid
If you're doing it to get power it won't really net you much power especially if you're NA.
Get the largest chambered one you can. How it sounds is a subjective thing. If you heard one and like it, then get it. I have a very large 3" chambered SuperTurbo (#17769) to reduce noise. I'm also using a 3" Car Chemistry insert at the tailpipe too. I probably lost maybe 5hp coming from a 70mm GReddy straight through but I don't care. I've got enough ponies anyways for my own use. Check out the #17748 muffler. Catalog is online.
Old Mar 29, 2007 | 06:36 PM
95bluse's Avatar
Agreed... #17748 is the one you need. I'm getting the 2 1/4" inlet one...#17747.
Old Mar 29, 2007 | 06:51 PM
black95max's Avatar
i have a 2 1/2 b pipe from budget so shouldnt i get a muffler with the same size pipe? im confused. and no im not getting it for power. u dont get hp from a muffler. i just need one for a little sound.
Old Mar 29, 2007 | 08:40 PM
MaximaSpd85's Avatar
#17748 or #17733 will work too, i had to get one to quiet down my last maxima and it worked perfectly.
Old Mar 29, 2007 | 09:23 PM
toddemullins's Avatar
The Borla Tubo doesn't sound bad in my opinion. It's a little louder than the #17748, but it's stainless steel and in your climate, it will last. $100 if you look online.
Old Mar 30, 2007 | 09:22 AM
TomV's Avatar
17793 works great for me. Its 3" and rated for 239 crank HP. Its not too loud even with a 2.5" unresonated b-pipe and a y-pipe.
Old Mar 30, 2007 | 10:33 AM
4x4Max's Avatar
No sorry it doesnt. Only time it soudns bad is with a test pipe. And i do have a y pipe.
Old Mar 30, 2007 | 12:40 PM
black95max's Avatar
thanks for the input fellas helps alot. picking this has been the hardest thing i had to do on my car
Old Mar 30, 2007 | 12:46 PM
sterlingmaxima's Avatar
dynomax sounds good might need to change your resonator though to get the best sound out of it
Old Mar 30, 2007 | 01:24 PM
95bluse's Avatar
Some people don't seem to realize that there are several different models of the superturbo. Obviously, if you get the 14" one & you have a y-pipe + b-pipe it will be loud. Getting the 17748 or 17747 which are both 20" will be good enough (as will other #'s that are large enough).
IMHO saying Dynomax sounds like garbage is like saying Nissan is slow
Old Mar 30, 2007 | 03:30 PM
uhh... nissan is slow.. and yea dynomax does sound like garbage... i wouldnt be saying that if i didnt experience it myself....
Old Mar 30, 2007 | 03:44 PM
95bluse's Avatar
Still haven't quantified your statement. I may be incorrect, we'll see when I have mine installed, but you have made a blanket statement with no proof to back it up.
Old Mar 30, 2007 | 03:58 PM
to the OP.......look if u like fart can sound exhaust that drowns then go with dynomax
Old Mar 31, 2007 | 06:23 PM
black95max's Avatar
everything really sounds like a fart can unless its stock or a v8. thanks for your input though.
Old Mar 31, 2007 | 09:34 PM
EnervinE's Avatar
i has college
Oh really? Is this what fart can exhaust sounds like now?
Old Apr 1, 2007 | 11:46 AM
yea its with a stock y pipe..........
Old Apr 1, 2007 | 02:43 PM
Apparition's Avatar
Ichiban King
All TRUE. POS!
Old Apr 3, 2007 | 02:39 PM
Graem's Avatar
I was thinking of putting one on my 97 manual with a ce y pipe, i have a stock b pipe but might upgrade to a budget b, what size inlet am i going to need and am i going to be able to install this myself i should i leave it to a shop
Old Apr 3, 2007 | 08:41 PM
The Budget B pipe is 2.5" O.D. pipe with a two bolt exhaust flange welded at the end. Unless the muffler is similar to the stock unit with an extension and two bolt exhaust flange, you will need to have a short piece of pipe with a slight bend in it with a two bolt exhaust flange welded on the end to mate up to B pipe. Most of the aftermarket universal mufflers do not have flanges. A qualified muffler/exhaust shop should be able to do it for you.
Old Apr 4, 2007 | 11:25 AM
95bluse's Avatar
Any update? Did you go with it or not?
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
09maxshawn11
Sep 30, 2015 10:28 AM
TheMafia
Sep 4, 2015 08:26 AM
