Which Clutch would you recomend?
Old Apr 2, 2007 | 02:51 PM
Litowcas's Avatar
Unfortunately my stock clutch died again, therefore I was looking for something stronger this time around. My current mods are motorstorm pulley, catman y-pipe, test pipe, custom maxima dual exhaust, and stillen intake. Just wanted your guys recomandations on which clutch i should get. I'm also getting a fidanza alluminum flywheel.
Also I am kinda interested in 3.5L swap maybe sometime in summer... So should I get like a stage II clutch instead?
Thanks for all the input
Old Apr 2, 2007 | 02:54 PM
moogotzskillz2's Avatar
Stage II is nice..
But from what i've heard/ and my personal experience. the 5th gen clutch is a good replacement. and it handles the 3.5motor. but if u plan on doing more than a 3.5 swap( SC, Turbo, etc..) i'd do the Stage II..
Old Apr 2, 2007 | 04:29 PM
Fr33way™'s Avatar
Wild for Width
The ACT Stage 1 will be fine for an N/A VQ35 setup.
If you want a replacement with a little more grip the 5th gen setup is hands down the recommendation of this board.
Old Apr 2, 2007 | 04:58 PM
99BlackMaxMS's Avatar
on the 5th gen clutch. Ive only heard good things about it on this fourm.
MDeezy's Avatar
Goalie Keg is having great success with his 5th gen setup + VQ35.
now is going to be the time to decide if you will or will no swap the 3.5L into your car. If you are not going to get the 5th gen clutch setup, If you are the same clutch could work but if you plan on being aggressive with it semi-frequently a beefier clutch might be desired.
Old Apr 2, 2007 | 05:05 PM
Litowcas's Avatar
so far im leaning toward ACT
Part #NM1-HDSS - Heavy Duty Pressure Plate, Performance Street Disc
Torque Capacity: 362 ft/lbs.
supposedly its the weakest one they have, but i think it will be plenty for 3.5L in the future...
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
