Installed H&R and Struts Question
Install my H&R spring and Tokico Struts love the way the car handles now but There is this noise every time I turn all the way to the right or left. I called the shop, told them about the noise, and was told that it is normal because the springs are turning with the wheel. OK is this true or BS it sounds bad! If it is true is there anything I can do to get rid of the noise. Has anyone else experienced this problem?
Did a search but could not find anything, Thanks
Originally posted by ejj5875
Sounds resonable. Do you know if the shop installed the rubber sleves on each end of the spring? If not, I would imagine that squeaking noise when you turn the wheel all the way would be pretty bad.
suggestion
Mine did that for about a week...tops. I decided to let it 'settle' a bit and it went away on it's own. If not, you might try the strut bearings on the front. Although this doesn't 'sound' the same as what you described.
Let it settle for a week or two and then go back to them.
SHUMAX
SHUMAX
Re: suggestion
SHUMAX
SHUMAX
The cups (seats) that the top of the spring sits on may not be installed correctly. When I installed mine I didn't orient them in the proper way and they creaked really bad when turning at slow speeds. SY showed me the notch on these seats that must face in a certain direction (can't remember if it is in or out) or it won't fit right, causing creaking and a slightly harsher ride. It was a somewhat easy fix for me, just jacked up the car, took wheels off, unscrewed the bolt from the top of the shock piston (located in the center of the strut mount in the engine bay) and was able to rotate the cups to the right position. Put everything back on and no more creaking.
95Maxi
35
Sep 2, 2015 10:37 AM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
