Screw missing on ecu, cant pull codes
Old Apr 2, 2007 | 09:57 PM
venompwr2's Avatar
I bought a Maxima a while back, and the screw on the side of the ecu to run the diagnostics on is gone. Not sure how that came out, but is there any way to fix it aside from using an obdII scanner (already have one) I just like things to be working properly. This is probably not something fixable, but I am hoping it is.
Old Apr 3, 2007 | 02:15 PM
Graem's Avatar
sorry for not answerign your question but my screw just spins without hitting the stops, so im in the same situation you are
Old Apr 3, 2007 | 04:33 PM
2da mizzax's Avatar
new ECU. Buy a scantool from Ebay. take apart your ECU and see if you can put it back together. as for the one that spins freely, you can prob feel the stops if you turn it gently.
Old Apr 3, 2007 | 05:47 PM
Kevlo911's Avatar
Kevlo for President
99's screw is there. It is a TINY white phillips head screw; look inside the hole with a flashlight. BE VERY CAREFULL using it.
Old Apr 3, 2007 | 06:36 PM
venompwr2's Avatar
Is it there? I used a small screw driver but I'll try again tomorrow. My other max's have been 95's and you cant miss that one.
Old Apr 3, 2007 | 06:43 PM
2da mizzax's Avatar
the screw is the same but it a phillips instead of a slot. if you look at it and cant see the screw there.............its not there.
Old Apr 3, 2007 | 06:44 PM
Kevlo911's Avatar
Kevlo for President
Yeah I know, only 99's have the tiny white screw. Use a flashlight
ballerchris510
Sep 10, 2015 09:35 PM
mix master
Sep 4, 2015 05:50 PM
