Apexi WS2 (97-99) owners... help!
Old Apr 3, 2007 | 02:45 PM
Chefasaurus's Avatar
Fire in the hole!
I bought and installed the Apexi WS2 about a month ago. The whole time I've had it, though, it's been clunking against something under the car. I trimmed the bumper, that didn't fix it.
I tried new hangers, that didn't fix it either.
It *looks* like it's hitting at the part that goes over the rear beam, up by the gas tank or trunk.
Just looking to see if this is a common thing, and how to fix it.
--Evan
Old Apr 3, 2007 | 03:29 PM
hectorc's Avatar
Upper Midwest Wheel Whore
Your car is too low, and it's the b-pipe hitting. There's a couple of wyas to fix it.
1. Raise the car alil
2. Have the B-Pipe cut, and extended to avoid the beam. I had the same issue with my custom exhaust.
Old Apr 3, 2007 | 07:41 PM
tedo007's Avatar
faster than you think
dont cut the bpipe jus change your springs
Old Apr 3, 2007 | 08:36 PM
Gismo-T's Avatar
B!tch We Got a Problem
Can't change teh springs...
He recently installed teh hottness of k-sport.
Old Apr 3, 2007 | 08:50 PM
jac121479's Avatar
i've got that along with a few other problems w/ my WS.
i had to remove my rear passenger side tow hook because it was hard up against that. after removing it, it started banging against the tow hook mount bracket. so i bent that outta the way (quick fix).
then it started hitting the exhaust hangar rod thats right behind the resonator on the drivers side. i trimmed it and that worked.
now it's up against the heat shield (in front of the gas tank) on the gas tank side. it rubs and squeeks pretty bad at idle.
and like your problem, over bad bumps, the b-pipe hit. my b-pipe hits before the highest point of the arc over the axle so i think shortening the b-pipe over by the resonator should fix both my problems. let us know what you end up doing.
Old Apr 4, 2007 | 12:59 PM
maximan57's Avatar
For me it was a bracket under the catback not far behind the cat. I had this problem after installing my Apexi ws2.
Your WS2 is hitting this bracket when you hit road bumps and the like.
Just remove the bracket. You don't need it, some new exhaust hangers will provide plenty of support for that great catback. Enjoy.
Old Apr 10, 2007 | 07:41 AM
petemo95se's Avatar
I had the same trouble with My Apexi exhaust. My fix came by using old-parts. About the time of the exhaust install, I changed the front sway-bar end-link bushings. You can use those to create a rubber "buffer" between the metal in the bracket. It worked perfectly for me and I've never had a clunk ever since. They fit right onto the exhaust hanger.
That's what I call "recycling" old parts.
Old Apr 10, 2007 | 01:21 PM
EteRnity059's Avatar
Boosted?....
Remove the rear tow hook on the left side of the car. i had the same problem. I also replaced my rubber hangers for the b-pipe and that allowed me to go over speed bumps without scraping the piping.
Old Apr 12, 2007 | 12:18 AM
JOMAN's Avatar
thats very good info i'll try some of this..i've had this setup for about a year and a half...and it seems i have a similar problem, i have troubleshooted the problem i still get the banging...any1 get the banging problem when going up steep hills like around 60-70mph?....anyways thnks for the insight if i find something that works i'll post it up!...
anyways guys how does your ws2 sound?...my sounds great with the warspspeed y pipe.
aw11power
Oct 10, 2021 04:57 AM
t6378tp
Sep 29, 2018 04:27 PM
Calabar
Oct 5, 2015 09:57 PM
0m3nc0w
Sep 11, 2015 05:21 PM
JoshG
Sep 5, 2015 10:10 PM
