00VI vs. MEVI
Old Apr 5, 2007 | 09:46 PM
NmexMAX's Avatar
dot dot dot ...
Good Lord, are you effing serious?
http://forums.maxima.org/forumdispla...aysprune=&f=79
http://forums.maxima.org/showthread.php?t=424641
Old Apr 5, 2007 | 09:54 PM
9378max's Avatar
maybe you should start with a y-pipe first
Old Apr 5, 2007 | 09:56 PM
NmexMAX's Avatar
dot dot dot ...
Headers, 00VI, EMU & wb02. Be done.
Old Apr 5, 2007 | 09:58 PM
9378max's Avatar
do you have a budget?
Old Apr 5, 2007 | 10:01 PM
NmexMAX's Avatar
dot dot dot ...
Make your own decisions.
Old Apr 5, 2007 | 10:11 PM
NmexMAX's Avatar
dot dot dot ...
Old Apr 5, 2007 | 11:57 PM
90stanza's Avatar
Originally Posted by Dan_E_Boi84
This is gonna be one by one so... whatever gives the best results is what I want.
I'm going to give you a big hint click on the links in NmexMax post.
Old Apr 6, 2007 | 12:45 AM
jxkim's Avatar
you should change the y-pipe first if youre looking for performance. i say do the b-pipe as well. and please do a little research because theres tons of info in the forums. and use this site (http://maxmods.dyndns.org/index.php) it has some basic info bout the mevi and 00vi. i suggest you start small before you go into something like variable intakes
its not all about big mods to improve performance/hp either... simple maintenance will go a long way and improve the way your car responds. cleaning the throttle body, maf, etc... changing sparks, filters, oil. having no codes (working o2 sensors and knock sensor) etc... ask anyone on the forums. these simple cost effective things are much higher on the list before you go adding a mevi or what not
sidenote: i love how "noobs" come in here and within the first 100 posts they start asking bout costs/install/etc on turbos and superchargers. haha. this is what fast and furious did to the car world! "push this red button and i go fast"
Old Apr 6, 2007 | 01:24 AM
Maximus_95's Avatar
trust me when i say y-pipe first... then worry about buying an 00vi later.
Old Apr 6, 2007 | 04:47 AM
RA030726's Avatar
I'm nutty for Nissans
fed spec conversion via stone racing headers
Old Apr 6, 2007 | 05:53 AM
andrei3333's Avatar
You are very right, neglecting on basic maintenance may not allow for power gains to be as high as they possibly can, its very important to first spend money on this maintenance and then only putting money into performance or whatever else you have in mind
Spark plugs, fuel filter, engine oil / filter, brakes, PCV valve, vleaning the TB and IACV, transmission oil, coolant, break fluid, PS fluid, and most of all tires, all these must be looked after first before buying intakes and exhaust. Why spend money on mods when u can RE-GAIN performance doing the basic maintenance first.
Old Apr 6, 2007 | 06:07 AM
GStrength's Avatar
Since ur a newbie, you should do a Mevi swap. The 00vi has its greatness but its a ***** to install if you dont know what your doing. People gonna tell you blah blah blah the Mevi makes you lose torque downlow, mannnnnnnn I HAVE NEVER FELT A DIFFERENCE DOWNLOW WITH THE MEVI. If anything you probally lose only a couple torque or hp, but its nothing noticable. But overall I rather do da Mevi for its convient hook up, and extreme hi end pull.
Old Apr 6, 2007 | 06:13 AM
NmexMAX's Avatar
dot dot dot ...
That's because it's a midrange loss. Aside from that, what we feel and what #'s show are completely different.
Originally Posted by One of my fav quotes
On the road testing is notoriously inaccurate. You don't feel power so much as you feel change in torque versus time. if the car feels stronger up top, that likely means you are noting a surge or increase in power at a certain point. This is just as easily attributed to making LESS power down low as it would be to making more up top. This is the same sort of "feeling faster" that all of the OBD-II track pipe people experienced. Same peak power, less midrange, and thus the car would have a much larger slope in the power band between the midrange and the high RPM range of operation. This is why the butt dyno should never be used. If you are going to try to make more power by messing with sensors, then do so with proper test procedures in place. A wideband to verify the AFR, as well as a timing light to check for any changes to ignition timing from changed load readings, is really required. The before/after tests should also be done on a dyno with the variables as controlled as possible to verify the change in power.
Old Apr 6, 2007 | 09:02 AM
LiGhtSoUt's Avatar
since you have a cali spec your biggest gain is gonna be in your headers and ypipe you can get the ones from ssautochrome that will give you agood gain and if you can do work then get the oovi after looking into it
Old Apr 6, 2007 | 09:07 AM
hacim105's Avatar
Just as he said, but also probably also including: catback exhaust. and possibly include: UDP, upgraded clutch, lightweight fliywheel.
Old Apr 6, 2007 | 09:10 AM
NmexMAX's Avatar
dot dot dot ...
I was trying to make it a sleeper ^^
Old Apr 6, 2007 | 10:35 AM
phenryiv1's Avatar
Mod her. Ate her.
Oh my D@MN, have we regressed a year? Is it Repost day? WTF?
Old Apr 6, 2007 | 04:21 PM
MorpheusZero's Avatar
Well, as long as new people keep joining, we'll never all progress...
Old Apr 6, 2007 | 06:07 PM
NmexMAX's Avatar
dot dot dot ...
I'm proud of myself, I 'warm' flamed, AND posted viable links...
Peanut butter flavor please...
Old Apr 6, 2007 | 06:38 PM
I'm proud of you too, man. I'm proud of you too.
But you get docked a point for liking peanut butter over chocolate chip.
Old Apr 7, 2007 | 05:48 AM
ethnic6's Avatar
umm, change ur exhaust first, then u can talk about oovi and mevi, oovi does put out more power, but the mevi is less of a headache
Old Apr 7, 2007 | 10:17 PM
markd248's Avatar
Anyone for mint chocolate chip or tin roof sundae???
litch
123
Jan 4, 2024 07:01 PM
t6378tp
Sep 29, 2018 04:27 PM
BkGreen97
Apr 2, 2016 05:47 AM
lrb6805
Sep 30, 2015 08:12 AM
Maximeltman
Aug 31, 2015 01:01 PM
