Next Best Mod?
Old Apr 7, 2007 | 12:10 PM
kismias7's Avatar
Next Best Mod?
I Have a '96 SE, 5 speed.
Mods so far:
Weapon-R Intake
GReddy Catback exhaust
Warpspeed Y-Pipe
What else can I do to get some more power?
Headers?
MEVI?
ECU?
What will help me the most?
Thanks for helping
Old Apr 7, 2007 | 12:13 PM
WielkiWaac's Avatar
MaximaDriver
00VI not MEVI
Old Apr 7, 2007 | 12:22 PM
gen4maxima536's Avatar
tune with an EU or vafc/safc
UDP (low hp/dollar ratio though)
put the car on a diet and shave some weight off it
Old Apr 7, 2007 | 02:28 PM
t6378tp's Avatar
Turbo 3.5
I would do a mevi or nitrous, if you ever plan to run nitrous than do not bother with the ecu but if you do not plan to run nitrous in the future get the ecu cause it will increase the gains of the mevi
one bad thing about the ecu is your stuck with the setting and you have to run 91+ gas
and headers for the cost and labor they are not worth it
good luck
Old Apr 7, 2007 | 02:36 PM
NmexMAX's Avatar
dot dot dot ...
Not in any particular order, but 00VI + headers + wb + piggyback.
Old Apr 7, 2007 | 02:42 PM
Fr33way™'s Avatar
Wild for Width
Just wondering, what is your suspension and braking setup?
Old Apr 7, 2007 | 02:44 PM
NmexMAX's Avatar
dot dot dot ...
Old Apr 7, 2007 | 02:47 PM
GStrength's Avatar
Originally Posted by WielkiWaac
00VI not MEVI
Have you ever driven your car with a MEVI?
Old Apr 7, 2007 | 02:56 PM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showthread.php?t=424641
Old Apr 7, 2007 | 03:05 PM
Gismo-T's Avatar
B!tch We Got a Problem
Good call...Don't wanna be driving around in a 4x4...
Brakes: Get some decent rotors & Hawk HPS pads
Old Apr 7, 2007 | 03:26 PM
Fr33way™'s Avatar
Wild for Width
Even if he drove a USIM with a knock-sensor code firing on five cylinders what bearing would that have on the facts?
Old Apr 7, 2007 | 03:42 PM
NmexMAX's Avatar
dot dot dot ...
Even if he drove a USIM with a knock-sensor code firing on five cylinders .....
Cripes, I had to drive home from work(30mi) like that once. FTL
Old Apr 7, 2007 | 03:43 PM
icedout's Avatar
00vi then a tune....then hold on
Old Apr 7, 2007 | 04:23 PM
Nismo's Avatar
You should be running 91 plus anyways
Old Apr 7, 2007 | 11:16 PM
Fr33way™'s Avatar
Wild for Width
I had to drive with the USIM today FTL.
Old Apr 7, 2007 | 11:30 PM
maxima_kenny96's Avatar
turbo.....
Old Apr 8, 2007 | 01:44 AM
MadMaxSE-L's Avatar
Doggah Bite...
Originally Posted by maxima_kenny96
turbo.....
420420420
Old Apr 8, 2007 | 07:14 PM
Fork's Avatar
Maximaler Experte
If you want a faster car, get a supercharger. Turbo's really are not designed well for our engine unless you're dragging but a SC, coupled with a light weight UDP really helps out. You'll loose low end power. Also, get rid of all your cats - she'll pass inspection when its warm. Next after SC is nitro.
But that's some serious coin. If you really want a faster Maxima, find a 3.5L 5 speed 02/03. Then start modding it.
Old Apr 8, 2007 | 07:18 PM
NmexMAX's Avatar
dot dot dot ...
I don't know where to begin.
Old Apr 9, 2007 | 07:13 AM
ethnic6's Avatar
I'd get headers first just because 00vi or MEVI is quite an advance stage... so I"d prep my car up to the task first
Old Apr 9, 2007 | 08:16 AM
laylow1988's Avatar
00VI not MEVI
mevi is great and will always stand by it ,if your a pretty handy mechanic then play around with the oovi for the added mid range thats suppose to be missing from the mevi (i have yet to notice the missing hp butt dyno of course) , ecu ,forget the headers unless u purchased the cattman combo with the y-pipe . spending money to get headers and then like another 300-400 hundred to install at a shop for an add 4-8 hp is not kosher with me but to each there own. unless u doing it yaself but still not worth it unless u go 3.5 which really should be all u should be thinin about and just say screw all these ather mods tilley i think has them premade for like 3 g's. if i knew someone around me that could work on a swap like that for me i would sell u my modds
Old Apr 9, 2007 | 01:04 PM
Ceasars Chariot's Avatar
Old Maxima Legend
plan for an 2000 Manifold swap, upgraded ecu w/ extended rev limiter and rpm switch. should be sweet !
Old Apr 9, 2007 | 01:19 PM
4x4Max's Avatar
buahahah....no
Ignore everything in this post.
Where do some of you guys come up with this stuff???
Old Apr 9, 2007 | 01:23 PM
Old Maxima Legend
well maybe fork should have stopped after: If you want a faster car, get a supercharger. that was pretty good !
Old Apr 9, 2007 | 01:26 PM
4x4Max's Avatar
I dont know about that one....the swap is pretty easy, there's nothing really 'complicated' involved in it, most parts are bolt-on without any custom fabrication needed. Use DE-K upper/lower/injectors/rail/tb, shave off a little bit on coil packs and rear valve cover, and you're good. Its not hard.
Old Apr 9, 2007 | 02:17 PM
Cdg2125's Avatar
I dont agree 100% with that. Yeah it's not a very hard process but there is more to it than people think, at least the new guys. Look how many threads there are in the all motor of people that can't get the car to run right. It's not complicated per say but does require some type of skill. Not everyone would know how to wire injectors, or the rpm switch, redo vacuum lines, etc. But I do agree its worth while. I like mine but will def swap in the 3.5 in the future ($$ permitting).
Old Apr 9, 2007 | 03:41 PM
RA030726's Avatar
I'm nutty for Nissans
i dont know about yous guys but you can have all the power in the world and it wont matter with crap wheels and tires. case in point my 15.3 @ 95
Old Apr 9, 2007 | 04:07 PM
jxkim's Avatar
i would make sure like some ppl said all the smaller details that will make your car drive better.
flywheel, clutch. tires. general maintenance (filters, fluids/oils, sparks) no codes. if you have all this stuff up to par, i would say next in line is suspension and handling. new struts/spring, bearings, mounts if needed, etc... throw on a front strut bar after and perhaps a rear sway bar.
the extra suspension will be much safer and feel better around any turn. then you should go ahead to the 3.5! i think itll be the best mod instead of trying to spend money improving the 3.0. i did my full exhaust and im not working on the engine bc next stop will be a 3.5. altho i love the vq30 and i dont mind driving around with it till that time comes
Old Apr 9, 2007 | 06:37 PM
NElsonAQuino's Avatar
welll.. i need a little help too. i have a 96 se 5speed completely stock.. what is the best performance mod i can do with like 300-400$ what should i do first?
Old Apr 9, 2007 | 06:39 PM
how do you get ur yellow sidemarker lights to stay on?? that looks sick that way?
Old Apr 9, 2007 | 08:03 PM
NmexMAX's Avatar
dot dot dot ...
... Nice trap How was that 60' IBdrivercan'tlaunch
Old Apr 9, 2007 | 09:08 PM
95turbo gxe's Avatar
Ill take Turbo for a 1,000 Alex!
Old Apr 9, 2007 | 10:05 PM
jxkim's Avatar
look through the forums beause there is like 294823094780293840 posts about this. use this site http://maxmods.dyndns.org/index.php
and quick answer: ypipe then bpipe or catback
Old Apr 10, 2007 | 11:33 AM
kismias7's Avatar
Thanks for the help guys! I had a few codes which I cleared. I am going to make sure my ks and o2 are ok, then get a tune up. I think I'll find a nice suspension setup and add strut bars, then go with the oovi. Thanks again!
Old Apr 10, 2007 | 04:12 PM
Cdg2125's Avatar
its 00vi not oovi. Could run into a problem trying to find oovi parts.
Old Apr 10, 2007 | 06:23 PM
NmexMAX's Avatar
dot dot dot ...
Cdg2125
That's in my top 3 pet peeves
Old Apr 11, 2007 | 07:16 AM
kismias7's Avatar
my bad 00vi, like it matters i know and you know what I meant. No need to make fun.
Old Apr 11, 2007 | 09:57 AM
Cdg2125's Avatar
it does matter. There have been a lot of guys that come in and say they can't find info on oovi and want help. The answer is that its 00vi not oovi. That's why people cant find stuff. It's just how life is. Knowing what you're talking about is important. It wasn't about making fun of you.
Old Apr 16, 2007 | 08:42 PM
24K on da way's Avatar
your next step should be:motostorm UDP & JWT ECU...trust me you will fall in love with your car....
lrb6805
Sep 30, 2015 08:12 AM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
