Knock Sensor Code not clearing?
Old Apr 9, 2007 | 08:22 AM
cardana24's Avatar
Blown
Has any one ever had the problem of not being able to clear a code? My 1995 GXE is throwing a knock sensor code, so I bought a new sensor and replaced it. Before I replaced the sensor I tried clearing the code with my actron scanner and it would not clear. I would press erase on my scanner and the results would come back saying that there was still one code remaining and it was the knock sensor code. So I got a new sensor. I put the new sensor in over the weekend, and drove the car a little bit. I am still getting the same thing. It will not clear with my scanner. Its not like I am clearing the code and it keeps coming back, but rather it will never clear. Has any one had this problem before? What was it?
the car is a 95 GXE with an 00VI, and JWT ecu.
....now that I think about it, my brother did splice into the knock sensor wire when he put my VAFCII in...I need to check that.
Old Apr 9, 2007 | 08:34 AM
Chefasaurus's Avatar
Fire in the hole!
You have to reset the ECU, not clear the codes with a scan tool.
This has been covered in the stickies.
Old Apr 9, 2007 | 08:45 AM
sky jumper
that's not true. the actron scanner will erase the code and reset the CEL. and the code will not come back if all is well. resetting the ECU is a different matter.
Old Apr 9, 2007 | 09:00 AM
cardana24's Avatar
Blown
I'll try reseting it with the screw on the ecu, but I really did not think there was a difference.
Old Apr 9, 2007 | 10:05 AM
cardana24's Avatar
Blown
I checked the connection for the VAFCII, and every thing looked fine. So I reset the codes with the ecu screw. Still the same thing. The knock sensor code will not clear. What gives?
Old Apr 9, 2007 | 10:13 AM
Welcome to the club........... see thread
http://forums.maxima.org/showthread.php?t=515963
Old Apr 9, 2007 | 10:30 AM
sky jumper
disconnect that controller from the KS circuitry (as I seem to recall, it should not use the KS on a 4th gen). if any wires have been spliced be sure they are clean. if that doesn't fix it, then your KS is still bad (possible) or you have a bad connection (also possible).
Old Apr 9, 2007 | 10:57 AM
cardana24's Avatar
Blown
Do you have an Air fuel computer hooked to your system? Is the KS wire tapped? Let me know, I am going to check my wiring and I may do away with that connection for my VAFCII if I don't need it.
Old Apr 9, 2007 | 11:12 AM
sky jumper
http://forums.maxima.org/showthread.php?t=446558
Old Apr 9, 2007 | 11:20 AM
No A/F computer, and the KS wire is not tapped. So, your VAFCII wire tap may not be teh issue. You could be experiencing what I'm experiencing. I never got a definitive answer in my thread. :bummed:
Old Apr 9, 2007 | 11:22 AM
2da mizzax's Avatar
may have overtorqued it and cracked the new one.
and wizard, you have tride to "erase" the code without installing a new knock sensor. and you wonder why it wont go away? (that is the gist I got from your other thread anyhow).
Old Apr 9, 2007 | 11:34 AM
Yes, I've tried to erase the code many, many times. And FWIW, my car doesn't feel sluggish at all anymore (fixed my issue relating to its "loss of power" issue that I described in my thread), so I don't think my knock sensor is hurting my performance.
Old Apr 9, 2007 | 11:43 AM
cardana24's Avatar
Blown
Originally Posted by sky jumper
looks like I need to cut the purple wire I have hooked to my knock sensor wire...I was just going off the pring out for hooking up the SAFCII. It looks like the purple wire on the VAFCII is something for the Vtec selenoid. Thanks for the link
Old Apr 9, 2007 | 11:59 AM
2da mizzax's Avatar
knock sensors dont care if you feel they are bad or not. you are getting the KS code for a reason. and you cant erase the code for a reason. THE KNOCK SENSOR IS BAD.
Old Apr 9, 2007 | 12:30 PM
cardana24's Avatar
Blown
Thanks for your reply. I guess I have three bad knock sensor then. I'll just go buy another one. Good idea.
Old Apr 9, 2007 | 12:34 PM
99BlackMaxMS's Avatar
I would try replacing the wire....its most likely the problem
Old Apr 9, 2007 | 12:36 PM
Dan_E_Boi84's Avatar
I've got the same problem... Just so you guys understand what he is saying...I'll do a write-up titled...
Cardana24's Problem for Dummys...
He hooks the actron scanner up to his car...he pushes the erase button with the engine OFF...then he waits for the scanner to do its job... then it says DONE or the more expensive Actron it says (FAILED...2 codes remain)...THE WHOLE TIME HIS ENGINE IS OFF...So he rechecks his codes and OH NO!!! THEY ARE STILL THERE!!!! Damn... That means it can't be the knock sensor... So he asks himself "WTF????"...."Maybe Maxima.org knows...???"
He he he.... sorry guys just gotta slow the bus down for some of the slow ones.... The code won't erase...NO MATTER WHAT!!!!
Old Apr 9, 2007 | 12:57 PM
cardana24's Avatar
Blown
Thanks for trying to clear that up. I am not saying that after I replaced my knock sensor the code is coming back. My problem is that I cannot clear the code...I cannot erase it. When I press erase on my scanner the scanner comes back saying earase is done..."one code remains"(its the knock sensor code). I am going to check something with my VAFCII wiring tonight...it seems like I have something hooked up wrong so I hope that is causing the problem. I will report back when I fix the wiring.
Old Apr 9, 2007 | 01:47 PM
2da mizzax's Avatar
My reply wasnt to you. but you are welcome anyways.
Old Apr 9, 2007 | 03:16 PM
cardana24's Avatar
Blown
alright, the problem was my VAFCII, I had a wire hooked up wrong. I cut that wire and now i was able to clear the code. hopefully it stays away. thanks for all the advice.
Old Mar 21, 2010 | 09:26 PM
tailbit's Avatar
I am having the same problem "can not erase the KS code even with a scanner". The check engine light went on for 02 sensor and KS, I first replace the 02 sensor and then try to ereae the code. O2 code is cleared but the KS code just doesn't get clear. I have tried it many many time but it still does not clear the code. Do I need to replace the KS before I can clear the code???? I always think that the code can be clear with the scanner even wihout fixing it (I also understnad the code will come back again in the future). Anyone can help me with this????
Old Mar 22, 2010 | 04:42 AM
EsQueue's Avatar
3 years old huh? I guess it beats starting a new thread. If the code comes back It simply means that the Knock Sensor is dead. I had the same o2 and Knock sensor codes. The o2 would clear and come back but the knock never cleared. Replaced o2 and Knock still didn't clear. Replaced Knock and code cleared as I expected it to do.
Old Mar 22, 2010 | 09:30 AM
tailbit's Avatar
Sounds like a solution, I will give it a try to replace the KS. Any tricks on how to replace the KS, I have seen a lot of people try to replace the KS with a lot of pain .......
Old Mar 22, 2010 | 02:24 PM
EsQueue's Avatar
No one who doesn't have a cali spec engine has the right to complain. LOL
I've seen walk throughs around here that even have pictures. I thought it was simple until I saw that it was nearly impossible to do on my car but I got it done with a swivle joint and a hanger to use as hands.
Old Mar 22, 2010 | 03:06 PM
balkan's Avatar
Video - Part 1:
http://www.youtube.com/watch?v=R2ntaxi7bXk
Video - Part 2:
http://www.youtube.com/watch?v=fPIMOIwLISc
Step-By-Step How-to:
http://forums.maxima.org/4th-generat...-tutorial.html
Old Mar 22, 2010 | 03:40 PM
Trini Boom's Avatar
What you need to do is disconnect the harness and then clear the code with the computer. After it is cleared, connect it back and start the car and scan for codes again. If it reappears, you would need to check the knock sensor for proper installation.
Old Mar 22, 2010 | 10:39 PM
tailbit's Avatar
You guys are great, thanks for all the input. I will order the part (KS) from ebay and install it then I will report back the result. Any more commnet are very welcome!
Old Apr 6, 2010 | 11:32 PM
rhonda sikes's Avatar
exactly how do you clear codes? with key on or off? turn screw back or forth or what. please tell me!
Old Apr 6, 2010 | 11:41 PM
Mistertones's Avatar
A OBDII scanner could do the trick.
Old Apr 7, 2010 | 02:02 PM
Dan0myte's Avatar
Originally Posted by balkan
"Some people say that it looks like a button hook. I don't know what the hell a button hook is because I'm not 80."
I laughed out loud at that one.
Old Apr 10, 2010 | 08:37 PM
Pullin3RD's Avatar
Word
mvm062
Nov 30, 2020 09:00 AM
ballerchris510
Sep 23, 2015 08:46 PM
Steven Orozco
Sep 12, 2015 10:41 PM
