Annoying little thing
Old Apr 10, 2007 | 10:16 AM
Socrates's Avatar
It really bothers me that the lighter/charger doesn't work when the car is off.
Is there any way to change that?
Old Apr 10, 2007 | 10:19 AM
andrei3333's Avatar
japanese cars its like that
Old Apr 10, 2007 | 10:47 AM
Cdg2125's Avatar
put another battery in the car and wire it directly to that battery.
Old Apr 10, 2007 | 11:12 AM
Socrates's Avatar
Well in that case why not run it to the main battery. A mobil isn't going to drain it.
Old Apr 10, 2007 | 11:14 AM
Cdg2125's Avatar
well there ya go then
Old Apr 10, 2007 | 11:47 AM
Socrates's Avatar
So you want to show me how to do it then?
Old Apr 10, 2007 | 02:36 PM
packerZ's Avatar
Really, you only have two chices for constant electrical to your cigarette lighter: a) tap into a constant hot wire in your wiring harness or fuse box...avoid a high draw circuit or you'll be blowing fuses if using a high draw appliance in the lighter socket at the same time tapped device(s) are on or (b) actually run a heavy gauge wire from positive battery post along wheelwell, through firewall and behind console to lighter post...not recommended/no fuse/no safety!
Old Apr 10, 2007 | 08:01 PM
Apparition's Avatar
Ichiban King
haha
Old Apr 11, 2007 | 05:55 AM
phenryiv1's Avatar
Mod her. Ate her.
Tap into the fuse box on the Hot side (use a multimeter or test light to determine which side is always hot) using a T-Tap. Run a wire from there to the back of the 12V socket. Put a fuse in-line. Prosper.
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
mpbclutch33
Dec 26, 2015 11:11 AM
bigfrank
Oct 1, 2015 12:51 PM
