1995 Maxima GXE Hard to Start
Old Apr 11, 2007 | 10:55 AM
unixsvr4's Avatar
Intermittently, my 1995 Maxima GXE would be very hard to start. It would crank while the key is turned, but simply would not start (see detailed descriptions below). The car has approximately 90,000 original miles on it.
When this happens, I would normally pump the gas pedal several times and then turn the key, but even if the car does start after repeated tries like this, occassionaly the engine would immediately die down. In this case, I would have to step on the gas pedal all the way down to keep the engine running.
After the initial moments of struggling, the car would typically run fine. There was one instance, though, that the engine stopped in the middle of the road after driving only a few miles after start. I was, however, able to start the car again right away and drive on.
The battery is new. At one point, the ECU showed that the Temperature Sensor in the Fuel-Pump Sending Unit (not the fuel-pump itself) was faulty, so I replaced the Fuel-Pump Sending Unit (not the fuel-pump itself). But the problem still remains. Nowadays, ECU would
show 0403 (Knock Sensor), if not 0505 (no problems detected).
Old Apr 11, 2007 | 03:37 PM
ivprodigy's Avatar
I have the same problem. Only when the car is cold... If someone can assist with that, it would be great!!!
Old Apr 11, 2007 | 03:50 PM
Dan's Avatar
Dan
No Longer Owns a Maxima
I also have intermittent starting problems. The car never takes more than 3 attempts 5-10 seconds each. Sometimes it starts the first try. My mechanic said I have the old kind of starter which doesn't have enough torque?
Old Apr 11, 2007 | 08:03 PM
Hammy
I Have the same problems as you guys, I've replaced the spark plugs, camshaft position sensor, fuel filter and still doesnt get better.
Old Apr 11, 2007 | 08:14 PM
OnEBadAsSi30's Avatar
Mine was fixed as soon as I fixed my knock sensor and replaced my fuel filter.
Old Apr 11, 2007 | 09:20 PM
Hammy
My car doesnt throw a code for the KS, should i change it anyways?
halfpol
Oct 17, 2022 12:16 PM
02PearlSE
Oct 7, 2015 02:12 AM
Team STILLEN
Aug 10, 2015 04:29 PM
halfpol
Aug 5, 2015 08:24 PM
