The ring on my Nissan keybroke....both of them. Pic included
Old Apr 19, 2007 | 06:22 PM
99seCALIforniCATer's Avatar
The part of the key that holds on to the ring broke on my first key a few years back so I got out my spare one and it did the same exact thing. Does anyone know if Nissan reimburses this kind of thing? I would just go have a couple extra keys shaved for cheap but my 1999 has a computer chip in it so I'm afraid it is going to cost a hundred or so either way.
It just seems like a waste of money to have new keys made just because of something stupid like this, especially when the key itself is still good. These things, out of everything, should last the longest I would think, no??
Anyone had to deal with this?? any input is appreciated.
Old Apr 19, 2007 | 06:26 PM
Dan_E_Boi84's Avatar
yeah and here is my solution...
Old Apr 19, 2007 | 06:29 PM
Tatanko's Avatar
Bacon Lover
That happened to one of my key fobs. Very annoying
Old Apr 19, 2007 | 06:32 PM
At least the fob is cheaper than the chipped key.
Old Apr 19, 2007 | 06:33 PM
Tatanko's Avatar
Bacon Lover
True, and I don't have chipped keys thankfully.
Old Apr 19, 2007 | 06:41 PM
dan.....did you make that yourself?
Old Apr 19, 2007 | 06:50 PM
eh...basically...my design but a friend took over the job....all it is is a piece of leather with a hole in the center where I pushed the actually key part through and then sewed it shut. Pretty easy and have no problems now. It beats paying 85 dollars for just a key blank and an extra 60 to program it.
Old Apr 19, 2007 | 07:34 PM
gunny11218's Avatar
that happened to my electric control, thingy, im not sure what you would call it but i think you know what im talking about. i drilled a hole straight through it and put a key ring in there, works awesome. and i too know what its like, its gay.
Old Apr 19, 2007 | 07:40 PM
99BlackMaxMS's Avatar
If you live in a safe area and do not mind dealing without the transponder chip then do this. (Your car will still be safe and no one will be able to break into it any easier than before, its just you will be disabling the transponder chip).
I would just take one of the two broken keys and tape in somewhere underneath the dash, out of sight. Then go to the hardware store (or somewhere that can cut a key for $5. Have them duplicate your key and go out to your car and use the key from the hardware store as your everyday key. By keeping the original key with the transponder chip underneath the dash, it will still recognize the chip and you will be able to start the car with the copied key. Problem solved for $5.
Old Apr 19, 2007 | 08:49 PM
andrei3333's Avatar
hey Dan_E_Boi84 ; could u sow me a hat please ? i could use a cowboy hat up here in Toronto! :-)
Old Apr 19, 2007 | 09:05 PM
nsnrider's Avatar
there is an easier solution for free, drill a whole in the key near the top, it won't get the chip since the chip is small and in the buttom corner. I have done this before for my customers who didn't want to fork out 100$ + for a new key but didn't want to loose their keys, all you need is a drill and a bit about 1/8" or maybe even smaller than that, don't remember exactly but just enough for your key ring to fit through.
Old Apr 20, 2007 | 05:22 AM
mikey chalupa's Avatar
My key fob handle thingy brooke not too long ago. I have been trying to find a way to fix it but I haven't had any luck yet.
Old Apr 20, 2007 | 06:37 AM
You can get one for less than $20 in the classified fourm
Old Apr 20, 2007 | 07:36 AM
Fasteddie01's Avatar
How about using epoxy to attach a metal key-ring? Looks like whatever you had keys on was pretty rough - maybe prev owner.
Old Apr 20, 2007 | 08:05 AM
willard00's Avatar
you can buy rubber key holder things for keys...around here i can get them at ace hardware.
http://www.acehardware.com/product/i...Id=20632020271
like those kinda...those might even work..
Old Apr 20, 2007 | 08:11 AM
1FSTMAX's Avatar
dangg same thing happen to my 99 keys... a 99 i30 limited key is on order..
Old Apr 20, 2007 | 12:03 PM
BlackMaxdout's Avatar
yeah, because you'll see gains from that, right?
Old Apr 20, 2007 | 02:47 PM
Fr33way™'s Avatar
Wild for Width
Happens to Toyota keys a lot.
Old Apr 24, 2007 | 07:21 PM
kris3983's Avatar
did anyone trie to drill a small hole in the upper corner
Old Apr 24, 2007 | 07:27 PM
Max_Out's Avatar
Under the radar
I was going to do that, but i instead took some epoxy and made a new loop. Then i sanded it down and painted it black... Walla! looked and worked great until one day it broke again.
95Maxi
35
Sep 2, 2015 10:37 AM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
95Maxi
Aug 25, 2015 08:01 PM
Team STILLEN
Aug 10, 2015 04:29 PM
