5-Speed Transmission Leak
Old Jul 11, 2001 | 02:17 PM
Weird Harold
Hello,
I was under my '97 Maxima last weekend and I noticed it appears to be losing a small amount of transmission fluid from the linkage connection. Does anyone have any experience with this type of problem? Is it serious? Is there some kind of seal in there that can be easily replaced?
Thanks,
Hal
Old Jul 11, 2001 | 09:57 PM
190hpKiLLA's Avatar
Granny Driven
Help him someone!!!
I have the same problem. Small lickage not dripping from some sort of plastic device on the 5 spd tranny underneath the car. It looks like plastic, has one screw, and wires in black insulation coming from it.
1) what is it?
2) how much?
3) driveable because theleak is very tiny, just check the tranny oil every engine oil change?
Old Jul 11, 2001 | 11:03 PM
BriGuyMax's Avatar
You should be fine...mine does it too....as long as it doesn't start dripping I think it's normal...my gear lube stays at the same level, but it never hurts to check it every once in a while.
Old Jul 12, 2001 | 04:59 AM
Daniel B. Martin's Avatar
Control Rod Oil Seal replacement
A minor leak may be tolerated, provided you check the lubricant level periodically and replenish as required.
You are referring to the Control Rod Oil Seal. It may be replaced with the transmission in the vehicle.
1) Raise the car and support it on sturdy jackstands.
2) Remove the shifter control rod from the yoke (nut and bolt).
3) Use a hammer and punch to remove the retaining pin. Take care to avoid damaging the boot.
4) Use hammer and chisel to remove the Control Rod Oil Seal.
5) Apply multi-purpose grease to the seal lip of the new seal, and then position it for installation.
6) Use a hammer and a deep socket of suitable size to drive the seal into place.
7) Install the retaining pin.
8) Reconnect the shifter control rod. Torque to 12 foot-pounds.
Please refer to the Haynes repair manual, page 7A-3.
Old Jul 12, 2001 | 05:23 AM
Re: Help him someone!!!
1) what is it?
2) how much?
No, you don't have the same problem. Weird Harold has a leak from the Control Rod Oil Seal. You have a leak from the PNP switch. There is an O-ring which prevents leakage at this site. That O-ring may be bad, or the plastic fitting secured with the one bolt may be cracked. Inspect, decide which problem exists, and replace the defective part.
James92SE
142
Jan 2, 2024 09:23 AM
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
Socalstillen
Sep 20, 2015 11:46 PM
