Help about a sound my car makes when trying to start
Old Apr 21, 2007 | 04:24 PM
Luisjo's Avatar
Hi, for about a week now when starting ("cold") it starts cranking and sometimes (almost everytime) i hear like a BIG...... "explosion". Ok the sound is like a "pop" but a damn big pop and im scared it will be the starter, i can get a video with sound, but since it happens 70% of the time i could not be sure to get it, also it started after i "tightened" the alternator/ac belt tensioner, but a friend of mine said that is not the problem since it does not give anymore problems than that.
BTW: when i said cold is what could you expect of a first start but at 87-97 Fahrenheit
Old Apr 23, 2007 | 10:41 PM
a32crazy's Avatar
i have the same problem did you find the problem why your car is doing that i seem to not able to
Old Apr 24, 2007 | 01:04 PM
EnervinE's Avatar
i has college
I've heard about this before, I think it's an intake backfire. Do a search.
Old Apr 24, 2007 | 09:50 PM
a32crazy's Avatar
can the s crank pulley be afecting this i changed it to unortodax
Old Apr 24, 2007 | 09:52 PM
x91max
sounds like timing belt jumped a tooth but i think urs has a chain
Old Apr 24, 2007 | 09:54 PM
TunerMaxima3000's Avatar
Useless info without a video
Old Apr 25, 2007 | 07:38 AM
Luisjo's Avatar
i will take the video now... so around 1:00 pm i will have it.
Old Apr 25, 2007 | 05:25 PM
XJinCT's Avatar
<3's the all motor section
agreed. as ****ty as it sounds... a 'burp' through the intake almost always indicates a timing problem.
Old Apr 25, 2007 | 05:26 PM
XJinCT's Avatar
not really if you know how to work on an engine and have worked on them for a while.
Old Apr 25, 2007 | 05:49 PM
Luisjo's Avatar
how could my car have jumped a thooth? how could this happen? (is that is the problem), i took a video but the "pop" sound didn't happened (tried like 8 times) but the sound does happens it just happens that today is my unlucky day
Old Apr 25, 2007 | 06:19 PM
crazy97's Avatar
Does it start rough?
Old Apr 25, 2007 | 10:54 PM
Luisjo's Avatar
well... when it does the "pop" i starts at the 2nd try, otherwise the 1st
Old Apr 26, 2007 | 06:31 AM
XJinCT's Avatar
well does the car start and run after? or just crank and make this pop noise?
Old Apr 26, 2007 | 07:02 AM
Luisjo's Avatar
starts and runs after.. sometimes second try, otherwise 1st
Old May 2, 2007 | 07:01 AM
brokedownmax's Avatar
if it was the timing chain id expect it to run rough, check fuel pressure, spark plugs?
Lakersallday24
Jun 16, 2019 01:35 AM
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
Jcof88
Aug 3, 2015 10:43 PM
