Noob question on grounding
Old Apr 23, 2007 | 12:12 PM
Keatz's Avatar
Hey guys i know this is a noob question but i was wondering if i wanted to install some ground wires, where and how would i exactly do this. I think my stock grounds are bad, so i just want to install additional ones. As far as i know i take one end of the wire connect it to the neg battery terminal and then run it somewhere, i just dont know where (as to the best spot to ground it). And, is that the only wire i would need to ground the car, or do i need to install more??? if so, where?
The main problem im concerned about is harsh starts at times. Car works perfectly when it started, but i seem to get a hesitant start, the car will crank and die, then when i turn the key back and start it again it starts. I check the bat, alt, TB, etc., everything is okay.
Old Apr 23, 2007 | 12:46 PM
Keatz's Avatar
I should also mention, when i was underneath the car, i noticed that the ground wire that should be connected to one of the exhaust hangers was just hanging, is that a big deal?
Old Apr 23, 2007 | 02:14 PM
Fang_DH's Avatar
Look in the stickies my man...theres a write up on how to do it.
Old Apr 23, 2007 | 02:32 PM
99grnmaxgxe's Avatar
http://www.activetuning.com/products...stallation.php
For you.
Old Apr 23, 2007 | 02:44 PM
EnervinE's Avatar
i has college
Those instructions don't look like they ground the starter...isn't that the most important ground in his case?
Old Apr 23, 2007 | 07:31 PM
Keatz's Avatar
i checked the stickies but i guess i missed it, i'll check again but that website that 99grnmaxgxe is awesome gives me a really good idea, thanks for the help guys.
Old Apr 24, 2007 | 08:44 AM
http://www.vqpower.com/v2/readarticle.php?article_id=630<---- I guess it was taken off b/c of the broken pics. But I guess you can read it for an idea.
Old Apr 24, 2007 | 08:47 PM
crazy97's Avatar
Run a wire from your starter to the negitive cable or a good connection on the body somewhere. Might be time to ditch your neg cable for a new one too.
Old Apr 24, 2007 | 09:54 PM
Trust him, he knows!
Old Apr 25, 2007 | 06:23 AM
Keatz's Avatar
thanks crazy97, i'll do that once it stops raining here. is it worth getting one of those grounding kits or am i just wasting 50 bucks???
Old Apr 25, 2007 | 08:39 AM
Don't get one, just make it. But if your grounds are good, you probably don't have to do anything lol.
Old Apr 25, 2007 | 08:47 AM
Fang_DH's Avatar
Def. make it, its not hard and ALOT cheaper, plus you get the same outcome!
Old Apr 25, 2007 | 10:51 AM
phenryiv1's Avatar
Mod her. Ate her.
Do the Big 3. MAYBE add the stareter re-ground. Prosper.
Grounding "kits" are a waste of money.
Pics about 1/2-way down the page...http://forums.maxima.org/showthread.php?t=505174&page=3
Old Apr 25, 2007 | 05:21 PM
Keatz's Avatar
thanks guys, i guess i'll just make it myself, appreciate all the input!!!!!!!!!!!!!
Old Apr 25, 2007 | 06:16 PM
crazy97's Avatar
Seems like yesterday when the car was useless.
AaronL
Nov 15, 2020 11:52 AM
Mar 12, 2020 12:06 AM
pktaske
Sep 4, 2015 08:40 AM
