how do you paint this part
Old Apr 24, 2007 | 04:41 PM
max2moon17
i was looking at other maximas and some people have their fuel injector cover (i think thats what its called), painted a custom color, i just wanted to know the steps of how to paint it.
Old Apr 24, 2007 | 04:49 PM
jvelos3's Avatar
its the cover for the coilpacks actualy. just remove it (u need hex screws) clean it, sand it, then primer and paint.
Old Apr 24, 2007 | 04:55 PM
max2moon17
do i clear coat it after, and is there any special paint i suppose to use? spray can or just paint with brush? sorry bout the dumb questions, i just don't want it to look crappy. thanks
Old Apr 24, 2007 | 04:58 PM
jvelos3's Avatar
yeh clear coat also. use spray can. and make sure to paint the edges and around the edges...to prevent pealing. you dont need special paint cause it doesnt get hot enough so any will do. I like duplicolor a lot...always worked for me real well.
Old Apr 24, 2007 | 04:59 PM
max2moon17
thanks alot man.
Old Apr 24, 2007 | 05:00 PM
fastisnothing's Avatar
ugh i posted too late. nvm. enjoy the painted coil cvr
Old Apr 24, 2007 | 05:06 PM
max2moon17
what was you going to say?
Old Apr 24, 2007 | 08:36 PM
clean and prep what your going to spray. apply multiple thin coats instead of one thick heavy one. do a coat, wait a few minutes let the paint start to dry, do another, let it dry, do this for about 4 coats. then let it dry a little bit again and do like 3 coats of clear, letting it sit for a few minutes between coats. 3 or so coats should be fine. more if you want its up to you
Old Apr 25, 2007 | 05:09 AM
max2moon17
what grit sand paper do you use?
Old Apr 25, 2007 | 05:23 AM
scubasteve's Avatar
OHHH YEA SCISSOR!!!!
light. i havent done it yet but i would imagine something like 400
Old Apr 25, 2007 | 06:36 AM
Max_Out's Avatar
Under the radar
I accually had a really nice write up on this when i did mine... Let me see if i can dig it up for you.
Old Apr 25, 2007 | 06:39 AM
Max_Out's Avatar
Under the radar
Hey guys, I've started to paint my vavle cover today, and its lookin preaty sweet. I'll go through the steps for ya just to let ya know.
1.) Remove your valve cover (Easy Right)
2.) Sand off your stock paint. (i used 220 grit, keep from scuffing to deep)
3.) Wash with dish detergent, and MAKE SURE ITS COMPLETELY DRY AND CLEAN.
4.) Mask off any part you don't want painted (two tone only)
5.) Choose you paint wisely (i'm using Duplacolor Ceramic paint to stand up to the heat.)
6.) Start off with a light coat covering everything. Use even long strokes on all coats. let it dry for about 10 min. then repeat for second coat.
7.) for your third coat lay it on kinda thick to get good coverge.
8.) let it dry for about 5 hours then remove masking.
9.) now mask off unpainted area and repeat steps 6 and 7. (or you can hand paint ceramic paint on letters or any other area)
10.) now let it dry for a good week for paint to cure completely. you can reinstall it after about 5 hours but be carefull not to wipe or let to much dirt get on it.
you can do this with anything metal or plastic
PRESTO you have a Preaty new Valve cover right?
I can post some pics of my cover when its done
Hope this helps man, and good luck.
Sorry the cover is dirty, but you get the point.
Old Apr 25, 2007 | 09:18 AM
max2moon17
thanks alot maxout i will try it this weekend and i will post pics of it up
Old May 16, 2007 | 04:02 PM
vilmaxima's Avatar
take out the 4 bolts, its a plastic piece so u dont NEED to sand it but always better to (400 grit) and paint away!!!
Old May 16, 2007 | 10:12 PM
killerVQ30DE's Avatar
I'm not sure if I'm a fan or not.. one of the local members car..
Old May 16, 2007 | 10:33 PM
Cdg2125's Avatar
wasn't there another thread on this? You should sand with light grit at least so the paint sticks. I always clean and prime it but you don't have to. Do light coats as was said and clear it for protection. Just how I paint things. Here's my old one:
derekinthez
Nov 13, 2022 04:00 PM
MR2 T'd
Jul 9, 2021 05:06 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
Hdnseek
Sep 9, 2015 05:55 AM
