Knock Sensor
Old Apr 24, 2007 | 08:08 PM
midnight0045's Avatar
Knock Sensor
just a quick question.. ebay lists them 65 shipped... published auto parts websites lists upper 100's.. ??? ugh i hate ebay.. they are very misleading and tend to "lure" you in with prices.. is there such thing as a "cheap" oem knock sensor? if its advertised OEM maxima knock sensor.. is it the same thing as the published sites?
http://cgi.ebay.com/ebaymotors/NISSA...QQcmdZViewItem
thanks
Old Apr 24, 2007 | 08:11 PM
Mxrider52's Avatar
I support for what?
This one is OEM and tons of members have bought it. There nothing to worry about.
Old Apr 24, 2007 | 08:12 PM
much appretiated :-)
Old Apr 24, 2007 | 08:36 PM
andrei3333's Avatar
i want one too but cant buy with credit card, what to do what to do ????
Old Apr 24, 2007 | 08:47 PM
maximacruizer's Avatar
http://autopartsonlinecanada.com/
get paypal link to a separate bank account
Old Apr 25, 2007 | 08:24 AM
maximafrenzy's Avatar
Fuhget About It.....
From the looks of the ad, it looks legit, I would buy it.
Go buy a prepaid Visa card
Old Apr 25, 2007 | 05:33 PM
XJinCT's Avatar
<3's the all motor section
thanks
you sure your knock sensor is even bad?
Old Apr 26, 2007 | 08:17 AM
cam_honestiam's Avatar
I bought one from that seller on eBay...it is legit. Brand new, OEM quality, OEM part #, ALL LEGIT.
Old Jun 5, 2007 | 01:30 PM
Ricanprez1's Avatar
Just got mine from the same link.
http://cgi.ebay.com/ebaymotors/ws/eB...9421133&rd=1,1
I ordered on sunday and just got it in the mail.1 day shipping FTW. By the looks of it, it looks OEM NISSAN, will try to install b4 starting work today. Here is a pic of it.
Old Jun 7, 2007 | 01:56 PM
sarathyj's Avatar
Relocating the Knock Sensor
Ok! So I know have the knock sensor from ebay (for around $60). Called up a few mechanics to do the installation and most say that they don't work with parts supplied by the customer. A few do, but they are quoting in the $200s for replacing the knock sensor since it is under the intake manifold.
Called the dealer just to check on their charges. The dealer says that they can just disconnect the existing KS (without removing it) and install the new KS in a diffenent place in the engine block so that there is no need to take out the intake manifold. ($280 including a new KS)
This seems like a good idea. Has anyone tried relocating the KS to a more accessible place? Any suggestions on where? Tried to get some info from the dealer but he is not giving out much info.
Old Jun 7, 2007 | 03:12 PM
ucmet011's Avatar
it isn't that hard to change the sensor. just need a 12mm socket and a long extension. it just took me about 1/2 hour to change mine. the hardest part is puttin it back in. i did it without removin any other thing on the engine.
Old Jun 7, 2007 | 06:47 PM
al7601's Avatar
I have to replace mine too and you made it seem easy. Do you have any directions as far as where it is?
Old Jun 7, 2007 | 07:02 PM
sarathyj's Avatar
Relocating seems a much easier alternative. Just leave the original in place, just disconnect the harness, connect the new KS and mount it at a more accessible place in the block. I'm just struggling with whereelse to mount it. Seems that the dealers are taking this approach these days.
Old Jun 7, 2007 | 07:41 PM
killerVQ30DE's Avatar
Your kidding yourself I think.. it takes 20mins or less to remove and add new KS in the Factory location. Your trying to 2nd guess Nissans R&D and put it in another location which may not give accurate readings and may just end up retarding not advancing your time..
Don't re-invent the wheel, just sockets and extensions + 20mins=Job done!
Old Jun 7, 2007 | 08:56 PM
ucmet011's Avatar
it is located under the intake manifold. i just used a long *** extension with a swivel end and a 12mm socket and i was able to get my off easy. then i swapped them out. then i placed the new sensor over the old hole. i place a small piece of cardboard in the socket to hold the screw in there and i put the screw in the hole and keep turn till it caught the screw hole and tighten itself up. the hard part was gettin the the into the new sensor and tighten it. that took me a little bit.
Old Jun 7, 2007 | 08:59 PM
andrei3333's Avatar
^ horse$hit, no Knowledgeable nissan service tech will tell u to change the desing of the VQ, there is a good reason nissan stuffed this sucker down in there, its the centre of the engine (more or less) and its the best place to be if u wanna sense knock. i think that nissan tech who u spoke to is on crack or just lazy plain and simple.
read the FSM, any nissan dealer will read the EXACT same FSM if u get the work done there, it tells u to remove the UIM so u can torque down the KS properly, the bloody method every one else on this site is using (including me this coming saturday) is wrong none the less, its impossible to get it torqued down correctly, so what happens ? the sensor is either more sensitive then it was designed to be (too tight) or not sensitive enough (not tight enough). its a hit or miss kinda thing.
for those who have no patience, knowledge, money or whatever else it takes to pull the UIM and do it right, this is the only way to replace it. Please do not relocate it anywhere!
Old Jun 7, 2007 | 09:04 PM
ucmet011's Avatar
my engine wont start now so i have no clue if the knock sensor it working
Old Jun 7, 2007 | 09:08 PM
andrei3333's Avatar
KS has nothing to do with ur engine not starting
Old Jun 7, 2007 | 10:13 PM
ucmet011's Avatar
well at first the car wouldn't fire which a KS mite be at fault. but now it wont turn over at all. which i think it is the ignition switch. but we was able to bypass it with a remote ignition switch and while usin startin fuild, it back fired and blew up in my intake and ****ed up some ****. anyone have any clue why my car doesn't want to fire?
Old Jun 7, 2007 | 10:48 PM
andrei3333's Avatar
huh ?
re-read ur post and see if it makes sense, then retype it
Old Jun 7, 2007 | 11:45 PM
Cdg2125's Avatar
you put starter fluid in your engine? You're kidding right?
Old Jun 8, 2007 | 07:31 AM
brandnew's Avatar
huh
Ummmmm WTF.......
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
