How to change Starter
Old Apr 25, 2007 | 09:23 AM
maxib2's Avatar
I couldn't find a write up on this so posting it here. I have a 97 GXE and need to change the starter on it. Often it gets stuck and won't turn, I can get it to work after tapping on it with a rod or something else. Can someone please tell me how to change it Step by Step or have any drawings showing how to do that. Thanks.
Old Apr 25, 2007 | 09:28 AM
JwaxMax99's Avatar
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old Apr 25, 2007 | 12:02 PM
cardana24's Avatar
Blown
disconnect the batter and move your intake assembly. unhook the hot wire and ground plug to the starter. then take out the two bolts. If I remember right the one closest to the radiator is a 14mm and the one closest to the fire wall is a 17. after the bolts are out the starter will pull out.
Old Apr 25, 2007 | 04:24 PM
tedo007's Avatar
faster than you think
you better find some good breaker bar
Old Apr 25, 2007 | 04:46 PM
jmello's Avatar
By some strange coincidence, I changed the starter on my 95 SE this morning. Yes, the bolts are 14 and 17mm. I completely removed the battery and intake up to the intake manifold to make room, and I didn't have problem breaking loose the bolts with my cheapo 6" ratchet set.
I also replaced the fuel filter, cleaned up my grounding points, cleaned the IACV and replaced the battery while I was in there, took me about 10 hours total, I left the battery at AutoZone to charge overnight and get tested.
Old Apr 26, 2007 | 01:08 PM
maxib2's Avatar
Thank you all for replying. I got the starter from the wreckers today ($70), will change it this weekend.
Old Apr 26, 2007 | 02:23 PM
nick_auto96's Avatar
Also, this might help too http://www.motorvate.ca/mvp.php/516
user 11122324
42
Jul 18, 2022 03:35 PM
Excalibur23
Oct 13, 2015 04:33 PM
msellas
Sep 23, 2015 09:16 PM
homewrecker
Sep 23, 2015 03:41 AM
