Trouble With Wheel Caps
Old Apr 26, 2007 | 03:52 PM
Da_Shatterer's Avatar
I'm having some trouble getting the wheel caps on the rims I have mounted on the back of my car. There seems to be this little golden piece underneath that's preventing me from putting on the caps correctly. Anybody have any ideas as to how I can get the caps on? Will I have to remove the rims and rip off that golden piece out? Any help would be greatly appreciated. Thanks.
Old Apr 26, 2007 | 04:57 PM
pmohr's Avatar
No more Maximas...
You mean the dust cover on the rear hub?
Old Apr 26, 2007 | 05:26 PM
I guess so. Is there any way to fix this problem?
Old Apr 26, 2007 | 05:31 PM
gen4maxima536's Avatar
wheel spacers?
Old Apr 26, 2007 | 05:34 PM
Thing is that they little golden caps are on the back wheels but not the front. Is it supposed to be this way?
Old Apr 26, 2007 | 08:33 PM
yes, there was just a discussion about this, the caps keep dirt and what not out of the bearings and all that back there. the fronts are set up different so they don't have the caps
Old Apr 26, 2007 | 08:36 PM
Is there a way to remove them? If so, would that negatively impact the rear brakes in any way?
Old Apr 26, 2007 | 10:15 PM
95 Maxnout's Avatar
Use the wheel spacers.I had to do the same thing.
Old Apr 27, 2007 | 10:06 AM
How big of spacers will I need? Will 5mm do?
Old Apr 27, 2007 | 03:14 PM
Doriftomodachi's Avatar
Some pictures would really help
Old Apr 27, 2007 | 05:32 PM
Now I guess I have to buy some wheel spacers, but I can't figure out which of these I would need? Any input guys would be greatly appreciated.
Old Apr 29, 2007 | 05:30 PM
max ride 41's Avatar
nooooooooooooooooooooooooo, do not use wheel spacers!!!! they'll screw up the bearings and offset your rears . look, go to a dealer, if these are stock rims then they can fix easily. they probably won't charge you unless they want to charge you for 10 minutes. if aftermarket, your probably screwed.
captchaos
Mar 15, 2016 12:18 PM
RWCreative
Sep 21, 2015 11:01 AM
240tomax
Sep 13, 2015 03:28 PM
dcam0326
Sep 8, 2015 11:02 PM
