service engine light poped up
Old Apr 29, 2007 | 02:10 PM
Louie Max's Avatar
I have a short ram intake and today i took off my K&N filter to recharge it and i sprayed the mass air flow sensor cleaner inside the throttle body and on the sensor . After cleaning the filter and letting it dry i installed everything back and i started the engine, i then realized after i started the engine that i forgot to connect the mass air flow sensor plug, so i turned off the engine, connected the plug and started the car and then boom the service engine light comes on. the car drives fine and sounds fine, could have the maf sensor gone bad?. thanks in advance for all your help
Old Apr 29, 2007 | 02:12 PM
EnervinE's Avatar
i has college
The light came on because you had it unplugged. You have to reset the ECU before it goes away.
Old Apr 29, 2007 | 03:26 PM
Louie Max's Avatar
thanks...
how do i reset the ecu?
i cant seem to find the sticky on it
thanks
Old Apr 29, 2007 | 03:30 PM
NmexMAX's Avatar
dot dot dot ...
You haven't even tried looking for it
http://forums.maxima.org/showpost.ph...49&postcount=1
Old Apr 29, 2007 | 06:29 PM
Louie Max's Avatar
thanks for your help =]
On a another note while cleaning the TB i found some oil there.. where could that have came from?
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
Flores94
Aug 11, 2015 12:53 PM
bassmann
Aug 3, 2015 07:53 PM
