engine coolant temp. sensor
Old Apr 29, 2007 | 03:57 PM
maxim82's Avatar
does a bad temp sensor make a car stall frequently and would it decrease my gas mileage
Old Apr 29, 2007 | 03:59 PM
NmexMAX's Avatar
dot dot dot ...
Yes, and probably.
Old Apr 29, 2007 | 04:02 PM
maxim82's Avatar
there are two different temp sensors for the 95 maxima which is the correct one
Old Apr 29, 2007 | 04:29 PM
NmexMAX's Avatar
dot dot dot ...
Refer back to the ECU for codes for further information.
Old Apr 29, 2007 | 05:36 PM
bmiller95max's Avatar
yes, i will tell you from experience. i thought it was my MAF, so I replaced that and nothing changed. i read up on the org and concluded it was the coolant temp sensor. i bought a new replacement from ebay, replaced it, and it righted itself. once you replace the sensor, make sure you reset the ecu. hope this helps!
Old Apr 29, 2007 | 08:42 PM
Luisjo's Avatar
my car had a bad coolant temp sensor, the car stalled, turned off randomly, and had a bad as **** gas milage so you should change it if it is bad.
Old Apr 29, 2007 | 09:30 PM
maxim82's Avatar
im defenitly getting all of the above, gas mileage went from about 310 miles on a full tank of gas to like 230-240. my car also turns of randomly when at a complete stop oh and at times its hard to get started
Old Apr 29, 2007 | 10:42 PM
Luisjo's Avatar
Yep, thats the one
Old Apr 30, 2007 | 08:48 PM
maxim82's Avatar
replaced the sensor today and the car already feels better, it seems to be running a little bit smoother and hasnt stalled....yet. it was worth the $25
MR2 T'd
Jul 9, 2021 05:06 AM
mvm062
Nov 30, 2020 09:00 AM
captchaos
Mar 15, 2016 12:18 PM
6spd4dsc
Mar 4, 2016 05:19 PM
dcardello
Sep 3, 2015 11:44 PM
