Catalytic Converter Bracket?
Old May 1, 2007 | 04:44 PM
kxmike's Avatar
I have a 99, the hanging bracket on my catalytic converter that attaches to the two rubber isolators rotted away. Now only the muffler and Y pipe are holding up the whole exhaust system. Is there an easy way to replace this mount with something else?
Old May 1, 2007 | 04:46 PM
Frank Fontaine's Avatar
I had Midas weld mine for about $50. The weld lasted 2 years, not there is a slight rattle again.
Old May 1, 2007 | 05:18 PM
WhiteA32's Avatar
Its called the Y-pipe bracket, you can get one from the dealer for like 48 bucks last time I checked. Or you can buy it used from the classifields. But personally you don't need it...
Old May 1, 2007 | 06:48 PM
kxmike's Avatar
So the Y pipe bracket is attached to the converter right? Just want to make sure we`re talking about the same thing. No part of this converter or flex pipe can be welded, it`s too rusty.
Old May 1, 2007 | 07:01 PM
WhiteA32's Avatar
Well its connected to the y-pipe via the bolts that hold the cat and the y-pipe together...
What I have seen some people do is they leave the rubber hangers up and just put a rod through the rubber hangers and it supports the y
Old May 2, 2007 | 05:50 AM
maxprivate's Avatar
Black Lion
you should be fine without it but i did notice a little rattling with it being totally rotted away. now that i had it replaced with new vibration rubber mounts problem is all gone. do it the right way and get it replaced.
Old May 16, 2007 | 03:24 PM
vilmaxima's Avatar
the part u need is a y-pipe bracket, all u gotta do is remove the 2 nuts that hold the cat to the y-pipe and remove from hanger put in the new one.
I suggest replace it soon, I left mine and my whole exhaust eventually started to sag
Apr 16, 2020 05:15 AM
Calabar
Oct 5, 2015 09:57 PM
09maxshawn11
Sep 30, 2015 10:28 AM
sliptap
Sep 30, 2015 05:57 AM
carid
Sep 9, 2015 05:06 AM
