Low end torque
#44
Originally Posted by bigwee
Oh someone else said that. That it wears out the main bearings I think. Ummm... I guess I'm stuck after that.
#45
Originally Posted by materchan
put adjustable cam gears on and back off the cam timing. this might get you more torque, but it will be a dog in upper RPM's
#47
Originally Posted by Fr33way™
Put on the reverse hood from Fast and the Furious, END OF STORY.
#52
What do you guys think of a CAI? Is it worth the couple of hp? I searched and some say that it works well with a y pipe.
#53
#55
Originally Posted by stupidaznmunkey
headers maybe + keep stock pipping will keep all that low end, but it might give a small decrease in mid/high end
#57
Originally Posted by LeVeL
More low end torque? Am I the only one here who spins tires without even trying?
#61
Spinning tires is more an indicator of the limitations of our front suspension.
#62
Originally Posted by natty99
.....or that people don't know how to engage a clutch properly
though I know you were referring to the others..
DR's FOR DD!!!! FTMFW.
#63
Originally Posted by Apparition
I can spin the top of first by stomping down in toyo proxes, but much after that its all grip.
#64
Originally Posted by MorpheusZero
Why the hell do people say this? Toyo makes all sorts of different tires and the Proxes line spans a huge range of grip. Saying you have Toyo Proxes tires means absolutely nothing.
Proxes T1r - 215/55/16
#66
I'd just have expected more from you, that's all.
Hug? <3
Hug? <3
Hugs are good, but in fear of lovers, a handshake and nod will do.
(sound of external wastegate at 19si)
#67
#71
Wow this thread got thrown out of wack. I been reading and it doesnt look like there are many bolt ons. Can anybody throw some ideas besides a CAI and exhaust, please?
#72
Originally Posted by Cdg2125
it got off track because there was nothing left to say. CAI and exhaust are bolt ons. UDP is tech. a bolt on but you don't gain much power. Y pipe is the first bolt on you should do. If you read you would know it's a 15-20hp gain from it. If you have the money throw on headers as well. Pieced together they give good flow. Other than that things are custom. MEVI is bolt on but it requires wiring and knowing some things. 00vi is tech. bolt on as well but requires a lot more than bolting on the IM so I do not consider it bolt on. Injector wiring, rpm switches, tuning, etc. 3.5 is not bolt on. SC/Turbo not bolt on. Look at http://maxmods.dyndns.org/. It gives a run down on all mods and you can figure things out from there. Max is not a honda where everything is made to bolt to it. Gotta do leg work and custom work to get the better mods on the max. This was all previously stated but I tried to end it there. Do some research.
#73
#74
None of these bolt-ons give better low-end. You might see a small improvement with the 00VI but that's it.
#75
#76
Not sure if this would apply to the A32 world. But on my A33B, I added a larger MAF housing and coupled it with a SAFCII using sensor in/out #'s, and saw a TREMENDOUS improvement in throttle response. Darkest night/brightest day.
For you guys, you would have to 'bore' your stock MAF since your sensors don't come out and drop into other housings as easily. There are other metrics here that haven't been completely looked at or analyzed, bit for off the line throttle responsiveness this is the mod to do for A33B people, there is not reason at all for you guys to be the exception. Couple that w/ a PFTB, and you should be well on your way.
It could be all my mods compounded on each other helped, but I did notice a very big improvement when the larger housing & SAFC settings were the ONLY thing I changed.
Again, a piggyback AFC & wb is a must.
