Axle nut coming loose??
your wheel bearing may be shot now. You may need a new hub. Happened to me when I let a gut change my clutch. The ******* didn't retighten the axlenut, and despit me retightening it, it came loose again twice, and i found my wheel bearing was shot. I wound up just replacing the whole steering knuckle with one from a junk yard. (avoid having to press out the bearing and hub... etc...)
Originally Posted by 7jackmack
Do you have the castellated adjusting cap in place on the
nut and secured by the cotter pin ??
Originally Posted by Mxrider52
There is no such cap on the front. There is a cap on the rear. The front just consists of the hub, axle, washer, nut, and cotter pin.
Originally Posted by Zero-K
My '95 GLE came with the castle caps, but my '99 ES didn't. I wonder if it was something with different models, or maybe different years.
on my 97 there was a castle nut, and on my 99 it's just the nuts..
Originally Posted by 1FSTMAX
hey same here...
the caps are available at www.rockauto.com under the
brake/wheel hub -subsection -axle spindle nut. Theres a nice
clear photo . Under $2.00 for a pack of two.
Originally Posted by UncleMax98
Nissan was saving $0.25 by not installing the axel nut cap. Mine (98) does not have it, either. If you install the cap, I think there is a piece of rubber inside the cap so it won't vibrate and make noise.
could that be it?
boomerbrian
Nov 8, 2015 05:10 PM
follyburr
Aug 12, 2015 08:57 PM
