Question for the 4th Gen Guru's (Re:AirBag Module)
Old May 8, 2007 | 04:20 PM
99 Max ES's Avatar
In a car that has had its front AirBags Deploy, is the AirBag Module under the center console considered Scrap?
Also, If you want to put airbag-less seats into a 99 SE with Side Airbags, Can I use an Airbag module from a non 99 SE?
One more. If the AirBag light is flashing because no side airbags are plugged in, will the front bags still work in the event of a collision?
Old May 8, 2007 | 05:56 PM
pmohr's Avatar
No more Maximas...
Yes, possibly, and i believe no.
Old May 9, 2007 | 01:19 PM
Ruthless's Avatar
So, your saying that my air bags don't work? My air bag light has been flashing for days now....
I did the "fix" worked for about 1-2 months and its back again. Re tried the "fix" again with no luck.
Old May 9, 2007 | 01:56 PM
kcryan's Avatar
do you have side impact airbags? if so its likely your pass ones wiring harness
Old May 9, 2007 | 02:51 PM
Ruthless's Avatar
I agree with you. I dont know what the part looks like, and how much it is, but i think that is the problem based on what i am read. Does this mean none will deploy?
Old Mar 4, 2008 | 10:27 AM
DJ98MAXSE's Avatar
how does someone check whether the module is bad or it's the wiring harness? I have a 98 SE and my air bag light has been blinking for some time now.
stevesmax
Dec 17, 2020 11:57 AM
Finkle
Sep 27, 2015 09:53 PM
95Maxi
Aug 25, 2015 08:01 PM
MikesChevelle
Aug 10, 2015 10:53 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
