injector removal problem! Help!
Old May 9, 2007 | 12:32 PM
winman15's Avatar
Iv got the manifold off but when i take the injectors out, the engine starts filling with gas. I thought depressurizing the engine by pulling the fuel pump fuse prevented that but i guess not. Is there a fuel shut off valve somewhere? I want to try getting my injectors cleaned but cant have them out for more than a couple mins with the engine filling to the brim with gas. Any help is appreciated!
also, when i put the injectors back in, the gas recedes into the engine..where is it going? Is my car gonna blow up when I finally get it back together? thanks.
Old May 9, 2007 | 12:49 PM
f550maranello2's Avatar
what... did u run the car after removing the fuse??? cuz ur supposed to.. i removed all injectors tons of times and i never had that problem...
Old May 9, 2007 | 01:51 PM
gassian's Avatar
yea i removed my injectors as well with not that kind of problem...so take the fuse out then start the car till it dies..then start it again and kepp cranking...
GL
Old May 9, 2007 | 02:05 PM
Neo Raven456's Avatar
GL
What he said. After it stalls once, try to start it again but don't let it crank more than 5 times, just 2 or 3 cranks and you know your good. Excessive cranking can cause problems
Old May 11, 2007 | 08:54 AM
mad greek's Avatar
You got to depressurize the gas tank,take off the filler cap jack
Mar 12, 2020 12:06 AM
gustavison
Oct 4, 2015 06:50 PM
Colossus
Sep 9, 2015 05:46 AM
